General 11th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Hybrid Winter Engine Warmup
Old Oct 13, 2024
HondaHopeful's Avatar
HondaHopeful is an unknown quantity at this point
Question Hybrid Winter Engine Warmup
Hello, I'm new here and am seriously considering a 2025 Civic Hybrid Touring Hatchback. I have a very short commute (4 miles each way) and am concerned that the engine won't warm up completely during the winter. Does anyone know about this? I'm thinking it wouldn't be able to make the whole commute on just battery power alone. I'm not well-versed on hybrids, as this would be my first one.
Old Oct 13, 2024
FRSam's Avatar
Click Here
Re: Hybrid Winter Engine Warmup
I'm not sure the car would warm up completely during normal weather, either. Your coolant, possibly, but I don't think your oil would.
The brief reading I did suggested the car can go 47-ish miles on full electric, which means it's probably close to 35. Either way, sounds like plenty to me.
Old Oct 14, 2024
Thanks FRSam, appreciate your help.
Old Dec 10, 2025
RosiethePuppy's Avatar
RosiethePuppy is an unknown quantity at this point
The engine itself will warm up about as quickly as any other internal combustion engine over a 4-mile commute but it will take much longer for the battery to warm up. So the car will be powered by the engine/generator/drive motor combo -- unless your commute includes some higher speeds where the motor would engage directly with the wheels via the clutch.
However, with this car it doesn't really matter whether you're running off battery or motor because it just does whatever is most efficient and it's all in the background. You just drive the car and don't worry about it!
I let mine warm up for 5 minutes in the driveway to give it a head start and I use the seat heaters to help with cabin comfort when it's cold.
ikenewton
Electronics
Jul 16, 2023 01:08 PM
coop
May 9, 2008 09:34 PM
imported_Sam
May 29, 2006 10:23 PM
Rokki
May 11, 2006 12:09 AM
aZnVoYCe
Jul 5, 2002 04:22 PM
