Customize your car Post here for any custom modifications you want to to to your car!
Tach in 2003 DX Coupe
Old Aug 13, 2022
Mr365truck's Avatar
Mr365truck is an unknown quantity at this point
Hello all,
I've done some research on installing a tachometer in an '03 DX, and I've determined the best option for me is to swap out the instrument cluster. I've got 2 questions: will anything need to be done to the wiring, or is it just plug n play? 2nd, how difficult is it to swap the speedometer between the two, as I'd like to retain the mileage. I should note that I'm planning on getting this cluster off of ebay https://www.ebay.com/itm/324645249801
Old Aug 13, 2022
Colin42's Avatar
Re: Tach in 2003 DX Coupe
95% sure you can't swap the odometer over.
Old Aug 17, 2022
gatrhumpy1's Avatar
gatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of light
You have to swap entire gauges.
Also, if you get a gauge with less mileage than you have now, you have to correct it to the right.mileage for your car. You have to research how to do that.
What I did was just use my old gauge until it was within 1.mile of the new gauge, and then wired everything up to tue new gauge. It is NOT plug and play. You have to rewire the wires.
Old Aug 25, 2022
Mr365truck's Avatar
What wires did you have to rewire? I've just completed the swap and everything works but the gas gauge. I know the gauge itself works because when I do a cluster test it moves just fine.
saintbrianmyers
Oct 8, 2013 01:21 AM
2001CivicDx
Aug 3, 2013 01:33 PM
bce22
Apr 9, 2009 07:23 PM
jciam
Oct 16, 2008 06:22 PM
InsaneImages
May 16, 2006 09:00 PM
