Rear Control arms, rear tire wear early models the early models had an issue with the rear control arms (upper) and have a tendency of rapid rear tire wear
Rear adjustable Camber kit or all rear bushings? Or both??
Old Apr 21, 2021
Ancv43's Avatar
07 Honda Civic Ex
Ancv43 is an unknown quantity at this point
Hello, I bought this 07 Honda Civic ex, the front suspension and alignment is flawless but both rear top tires are leaning inwards and both tires have worn tread inside part of tire.. I replaced rear brakes,rotors.. I’m in process of replacing both rear hub bearings and as I’m looking the upper control arm camber is non adjustable.. Someone told me if I replace all the rear bushings it might fix rear alignment but I say I don’t think it will.. Should I replace upper control arm with an adjustable camber kit?? If someone can please advise me on what easiest route,, .. Thanks in advance 🙏🏽
Old Apr 22, 2021
Re: Rear adjustable Camber kit or all rear bushings? Or both??
not performance modifications, rather the rear suspension mechanical issues on early models.
moved your thread to the proper section of the forums.
read around where we placed your thread.
Old Apr 22, 2021
BrotatoChip's Avatar
Super Moderator
And also this sticky one section back.
https://www.civicforums.com/forums/3...ic-hybrid.html
SpecialKPB
Jan 16, 2014 03:36 PM
dadsrevenge
Feb 18, 2012 04:35 PM
Justinsn95
Jul 29, 2010 11:10 PM
TeLLy
Jun 10, 2009 01:01 PM
Grey
Aug 19, 2002 08:49 PM
