Rear Control arms, rear tire wear early models the early models had an issue with the rear control arms (upper) and have a tendency of rapid rear tire wear
06 civic terrible rear suspension?
Old Aug 20, 2012
GGibson01's Avatar
GGibson01 is an unknown quantity at this point
I have had nothing but problems with my rear suspension. I get it aligned and then it seems that the tires are pitting again at my new rotation 5k miles later. I literally just drove from Logan, Utah to Austin, tx (1500 miles?) and just in that distance the alignment was off.
Anyone else have this problem? I know that the rear (tie bars?) were subject to a issue warning but not a recall.
When i take it to shops, they say 'well we can replace one part at a time and see if that does it' indicating that they have no real means to diagnose this problem.
Any help/ ideas/ commiseration?
Thanks,
Gregory Gibson
Old Aug 20, 2012
Re: 06 civic terrible rear suspension?
defective rear control arms. replace with updated honda part or aftermarket, otherwise you will go thru tires every year. its a very common problem on 06+ civics.
Old Aug 23, 2012
speedy25's Avatar
speedy25 is an unknown quantity at this point
I'm going to guess that you have been going to chain service stores. Nobody should be telling you they will replace parts until the problem stops.
Find a REAL alignment shop that knows how to repair suspensions AFTER you check with Honda on the rear arm update.
-SP
Old Aug 31, 2012
ubnpast's Avatar
ubnpast is on a distinguished road
Pictures? What kind of tires?
Old Sep 9, 2012
badolboy's Avatar
RED ROCKET
badolboy is an unknown quantity at this point
me too 06 coupe 3 sets tires and now
full susp. upgrade w/ cambers kit?
anyone correct this issue w/ aftermarket parts?
this can get $$$$$$$$$.. jc
CascadiaBlue
Apr 18, 2015 09:13 AM
ej8
Apr 13, 2015 06:36 PM
CapYoda
Nov 11, 2001 05:17 PM
SleepyT
Nov 1, 2001 04:59 AM
