Air Conditioning Post issues about air conditioning here
AC problem
Old Jul 3, 2022
Carrito's Avatar
Carrito is an unknown quantity at this point
AC problem
Hello all.
i have a 2010 civic lx sedan with a strange a/c problem. The ac ( fans and compressor) will run for a bit usually until the car gets hot. Eventually the relays will start clicking on and off and they stop working. When this happens the compressor disengages, the ac fan stops and so does the radiator fan interestingly enough. The clutch relay is good (clicks when coil energized) also swapped with another for good measure. Clutch is good also. If I bypass the relay 30-87, (or 87a can’t remember) the clutch will engage while it’s acting up. Also while it’s not functioning, i only have 10v across the relay terminals. 13v on feed power to coil , but resistance on the ground (ecu side i believe) of the coil. For some reason the ecu seems to be intermittently providing a poor ground to the relays under the hood. Is there a separate ground for the ecu somewhere? Also the system has a full charge and no leaks. Thanks
Old Jul 7, 2022
2005-civic-vp's Avatar
2005-civic-vp is an unknown quantity at this point
Re: AC problem
Check refrigerant level? My compressor + fans wouldn't run at all until I put a can of Wallyworld refrigerant in and everything runs fine now with cold air again!
Old Jul 7, 2022
Carrito's Avatar
Re: AC problem
System is fully charged
Old Jul 7, 2022
BrotatoChip's Avatar
Super Moderator
Re: AC problem
Possibly the compressor clutch needs adjusted? A/C would work until the compressor thermal protector kicks it off.
MrShorty
Air Conditioning
Sep 14, 2019 07:19 PM
dsm482
Air Conditioning
Jun 9, 2019 05:46 PM
2002CivicTDA
26
Jul 21, 2018 04:31 PM
BrotatoChip
19
Jun 28, 2012 05:11 PM
Texans75
May 23, 2012 11:53 PM
