Air Conditioning Post issues about air conditioning here
A/c line freezing have pressure switch question
Old May 6, 2021
Cmstackx's Avatar
Stack
Cmstackx is an unknown quantity at this point
I’m sorry if this is in the wrong place I’m still new and finding my way around.
I have a 2007 Honda Civic lx coupe, I’ve had it a few weeks now and I’ve had to replace quite a bit trying to make it a dependable daily drive, I’m really considering cutting my losses and selling it to find something else but I really like the car.. anyway, I’ve replaced the Mode Control motor, the blower motor/fan, the climate control unit, all the relays and fuses and that seems to have fixed some of my issues however, now I have notice my a/c line freezing up. The a/c blows cold and I only drive the car to and from work for about 20 minutes rash way. I recently started smelling Freon in the cabin and I’ve determined that it’s my a/c pressure switch. My question is, to replace the switch do I have to vacuum the Freon and have it refilled? Or can I just quickly remove and replace it and then fill it with a can of Freon from the auto parts store?
Old May 6, 2021
Colin42's Avatar
Re: A/c line freezing have pressure switch question
The system needs to be properly emptied, and then filled with a proper set of gauges. Before you get the shop to do that, if you're smelling freon inside the cabin it could be the evaporator leaking. Need to put dye in the system and see where the leak is coming from.
D17VTECPOWER
Transmission swap
Nov 5, 2019 05:33 PM
joenobodyyet
Transmission
Nov 28, 2018 06:48 PM
sierrawindy
Transmission
Feb 24, 2018 05:31 PM
kingholdem87
Aug 26, 2014 08:19 AM
markc
Apr 19, 2007 02:17 PM
