Air Conditioning Post issues about air conditioning here
AC Compressor clutch does not engage 2015
Old Jun 15, 2020
swampy_swimmer's Avatar
swampy_swimmer is an unknown quantity at this point
Hello, I inherited 2015 Civic with only 27K miles on it. I just discovered that AC blows hot air. Upon inspection I saw that compressor clutch does not spin when AC turned on.
I checked the fuses and tried to swap the relays, to no result. Unless I swapped wrong relays? What else can it be?
Thanks.
Old Jun 15, 2020
BrotatoChip's Avatar
Super Moderator
Re: AC Compressor clutch does not engage 2015
Could be low refrigerant. You would need a set of gauges to check.
Old Jun 16, 2020
I'll try to charge it. Do not have the gauges. But it seems like electrical issue to me. I notices that fans are not spinning. But it could be due to the cold engine.
mrohitredd
40
Sep 9, 2017 12:03 PM
got2run5
Jul 28, 2017 07:14 PM
bcledfoot
May 26, 2011 11:33 PM
Wykkid_darkness
Mar 26, 2011 05:33 PM
mrb420
Jan 21, 2006 11:34 AM
