Air Conditioning Post issues about air conditioning here
A/C Mag Clutch Replacement
Old Jun 22, 2019
3154tm's Avatar
3154tm is an unknown quantity at this point
hi all, newbie here and this i my first post. what a great forum! thanks to some very knowledgeable folks here i was able to diagnose an a/c problem as a bad field coil in the compressor clutch. i'm hoping someone can recommend an after market vendor for a replacement coil and clutch. thanks in advance.
Old Jun 22, 2019
Colin42's Avatar
Re: A/C Mag Clutch Replacement
Only available through honda
Old Jun 23, 2019
3154tm's Avatar
actually, finding a vendor is not the problem. there are plenty to choose from and the kits are not expensive.
but this is going to be a pita i don't want to have to do it again. so i'm hoping someone here can
recommend a vendor and product that they have had a positive experience with. thanks again.
Old Jun 24, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Sometimes it is just the air gap between the clutch and compressor that needs adjusting and not a bad clutch/coil.
Old Jun 24, 2019
3154tm's Avatar
ndnv, thanks for the thought and reply. unfortunately, the field coil has a break in the winding and will
have to be replaced. figured i might as well do the clutch while i'm at it. for no particular reason i
ordered one from these folks.
Amazon Amazon
supposed to be made by this outfit here in the USA
https://www.maxsamclutches.com/complete-clutches
they can be had cheaper by other vendors but hard to tell who and where they're made.
thanks again.
Old Jul 5, 2019
3154tm's Avatar
to follow up, the kit i bought has worked so far and there were no difficult problems with the install other
than the usual with the circlip/snap rings. fwiw, the snap ring pliers i ended up using were from OTC,
their part #0400 and worked really well.
https://www.otctools.com/products/15...ng-ring-pliers
Erbernator
Air Conditioning
Jun 13, 2019 06:39 PM
jerribird
Sep 11, 2010 07:30 AM
leonhsieh
Sep 12, 2006 07:01 AM
supsoop
May 5, 2002 12:32 AM
