Air Conditioning Post Issues about Air Conditioning here
A/C loss of power and Squealing
Old Jun 12, 2023
Airfox7898's Avatar
Airfox7898 is an unknown quantity at this point
1999 Honda civic ex/(CAD)Si
d16y8 manual
- - - hey guys , so recently went and got my A/C recharged and a low vacuum line installed (previous owner used rubberizing putty to “seal” a leak) and on the way home noticed significant power loss when I get on the throttle with A/C on. As soon as I turn the A/C off the power returns to normal (we’re talking like 50% power loss). Got it home and parked it, as soon as I turn on the a/c the idle starts to surge between ~400-1200 RPM (goes to normal once I turn a/c off. Went to see if the compressor was seized and it spun with a small bit of effort with spots where it seemed to catch/ drag around the same spot.
Here I am a week later driving home, a/c on, and I step on it in second. as soon as it got to around the 3500 rpm range I hear it start to squeal for a few seconds. Got home, took it out of gear and throttled it from under the hood and was able to replicate it from there, turned off a/c and did the same thing and no noise.
Does anyone know where I would even start to look? Thank you!
(P.S A/C was not overfilled saw for myself that it was vacuumed and filled to 1.43 LBS. (0.6KG)
the belt is also fairly new and doesn’t feel loose
EDIT: my dumb *** forgot to mention that while I was giving it throttle from the engine bay, I noticed that the compressor would disengage/stop turning after letting of throttle every time. Is this normal?
Old Jun 13, 2023
Colin42's Avatar
Re: A/C loss of power and Squealing
Compressor is probably starting to seize
Old Jun 13, 2023
Airfox7898's Avatar
Okay. And installing a new clutch kit should fix that up right? Or am I going to need a new compressor?
Old Jun 13, 2023
could be the bearings
Old Jun 13, 2023
Colin42's Avatar
Clutch wont fix the compressor if its the compressor bearings that are shot
Saphirestrong
Jun 8, 2021 08:14 AM
booba5185
18
May 14, 2006 06:17 PM
BoSS
Mar 28, 2005 04:10 PM
elitecivicex01
Florida
Aug 19, 2004 01:51 AM
nos1
Bolt-on Engine Performance
Aug 27, 2003 01:44 AM
