Air Conditioning Post Issues about Air Conditioning here
1999 Civic A/C issue
Old Aug 22, 2022
Livealatimmy's Avatar
Livealatimmy is an unknown quantity at this point
I am having a strange issue with my Civic. When the car is cold the A/C works great. But once it warms up (approx 10 min) the compressor clutch will shut off as soon as you give it throttle. But as long as you let it idle the A/C will stay on. The pressures when the compressor is on are 35-40 psi on the low side and 200 psi for the high side.
I can check the red wire going to the compressor clutch and confirmed that when i give it throttle I'm dropping voltage to my clutch. I've tried to switch the clutch relay with the condenser fan relay and I get the same result. I can feel the relay click when the clutch is energized. I'm hoping someone has some suggestions as to what I am missing.
I have replaced the following:
- Compressor
- evaporator
- condenser coil
- expansion valve
- pressure switch
- receiver drier
The original issue is still there.
Old Aug 24, 2022
Bugman1400's Avatar
Bugman1400 is an unknown quantity at this point
Re: 1999 Civic A/C issue
How low is the voltage dropping to when you give it throttle?
Also, why did you replace your entire A/C system? Who did the work?
Kyle Gleason
Jul 20, 2017 12:07 AM
mjdiaz89
Jun 21, 2016 09:26 PM
lrybrn
Jun 5, 2016 10:00 AM
artbesch
May 30, 2016 01:26 PM
bryan11
Aug 16, 2011 07:53 PM
