Regular Maintenance Post Questions/Information about Regular Maintenance here
Transmission Fluid Change?
Old Mar 4, 2024
Tonydavid's Avatar
Tonydavid is an unknown quantity at this point
My 2012 HONDA Civic has 118,000 miles. The maintenance minder says I should change the transmission fluid?
Also, when I’m accelerating, when I get to high 20s-mph and until I get into the mid 30s-mph, my car vibrates a little more aggressively and feels like it putters a little bit. And then when I go a little faster it’s fine and back to normal.
Do you think it is a good idea to change the transmission fluid. I got an hestimate of $240 to have the transmission fluid replaced.
Thanks in advance for your help!
Old Mar 5, 2024
Re: Transmission Fluid Change?
you drove 100k+ miles and never did change the fluid?!?
Old Mar 5, 2024
Colin42's Avatar
Fluid should be changed regularly, use the correct honda fluid
Old Mar 5, 2024
Tonydavid's Avatar
I purchased with 85K miles from friend who was good on regular maintenance so I assume they may have changed it. But I am not sure.
Old Mar 5, 2024
if he did not give you an owners' manual, you can download from Honda website.
It have the mileage recommended for changes.
moving to mechanical issues section of the forums, BTW
George356
Regular Maintenance
Dec 1, 2020 10:11 AM
GentleBen
General 7th Gen
Aug 13, 2018 03:07 PM
tharmon
Feb 22, 2014 08:27 PM
Digipixel
16
Jun 12, 2012 12:30 PM
green01civic
Nov 11, 2010 10:09 PM
