Regular Maintenance Post Questions/Information about Regular Maintenance here
Adding Water in Radiator
Old Aug 11, 2018
miendude's Avatar
miendude is an unknown quantity at this point
Hello! My friend added some bottled water into my radiator/coolant reservoir for my 2006 Civic EX (170k miles). He added about 1 bottle (16 fluid oz) and did it because the reserve was on the low side. Then I read later in the manual to never add water... So my question is, should I be worried? Or can I just simply add the standard Honda coolant over time and get the solution in the radiator back to normal? Should I drain it and put new coolant in just to be safe? Anyway, thanks for any help.
Old Aug 11, 2018
GolNat's Avatar
Prelude Owner
Re: Adding Water in Radiator
Yes you should drain it and put new coolant in make sure the mixture is correct. Also regular water will corrode the internal parts of the cooling system.
Old Aug 11, 2018
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Yes thats Correct ...
Honda coolling systems dont like tap water mixed in, reason behind it is that it could cause corrosion. use
(- hondas Long Life Type 2 pre-mixed 50/50 coollant- ) best stuff to use.even though some guys on here may
have there own brand they rather use i will only use Hondas Type 2 coollant, like on my 08 Civic owners manual says so...
https://www.honda.ca/Content/ownerma...CIV2-238-E.PDF
Old Aug 11, 2018
Bottled water is probably much better than tap water LOL
One pint isn't a lot. You could check the freeze protection of the liquid in the reservoir, and compare that to the liquid in the radiator.
If water was JUST added then there will be a difference. The plastic reservoir just lifts straight up off of its bracket, dump it out and refill with fresh correct antifreeze.
If water was added days ago, it's had time to mix with the liquid in the radiator and freeze protection readings will be pretty close to the same. See if it's sufficient.
OTOH if the car hasn't had a coolant replacement service done in the last 50,000 miles, it's due for one. Just dew it.
Old Aug 11, 2018
miendude's Avatar
Thanks for the info guys, total noob car owner so all of this helps alot! I probably won't have time to go get it flushed for like 30 days due to tight schedule, everything should be okay for that amount of time right? Commute is only about 30 miles round trip.
eager2learn
May 30, 2017 09:18 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
offtheheezay
17
Mar 10, 2015 05:26 PM
hhamin
Sep 3, 2012 05:31 AM
return_2020
Aug 4, 2005 08:44 PM
