1989 civic b18b1 to gsr
I bought a 89 civic sedan that already has a b18b1 swapped into it. I've been wanting to swap a different engine into the car because I'm sure the current one has bad rings, I've been thinking about doing a gsr swap, would it be simple? Would the mounts be the same? Would I have to change the harness? I've already decided to get a hondata and get it tuned so ecu isn't a issue. This is also my first time posting on a thread so I'm looking for as much input as possible.
Re: 1989 civic b18b1 to gsr
Never done it myself but you have a b series and you're putting in another b series so I don't believe you'd have to change mounts, harness may be different but it might not be
I’m pretty sure you only need to swap the harness. I’d try to find a trans too because the gearing is a lot sportier from a GSR trans, but you’d be fine with the one you have now.
Also, what makes you think that it's a piston ring issue?
ljprotheroe
Jun 22, 2018 07:45 AM
97_civic coupe
May 15, 2013 04:52 PM
