Air Conditioning Post issues with air conditioning here
Low heat at idle
Old Feb 2, 2023
Cranium1814's Avatar
Cranium1814 is an unknown quantity at this point
Low heat at idle
Can anyone tell me if its normal for a civic to blow cooler at idle then at higher rpms . It seems that at lower rpms my civic blows cooler then when I'm driving .
Old Feb 2, 2023
Colin42's Avatar
Re: Low heat at idle
Check the coolant level. Water pump could be failing
Old Feb 2, 2023
Wankenstein's Avatar
Here's a good read on no heat at idle https://rustyautos.com/no-heat-at-idle/
You can check the strength of the water-pump by removing the radiator cap at cold start. Start and run the engine until it reaches operating temp. With the cap still off cautiously look into the radiator neck and watch for flow (current in one direction) at idle. Take a video of the flow and post it here.
Coolant system bleed is likely needed.
Old Feb 3, 2023
BrotatoChip's Avatar
Super Moderator
Thermostat stuck open? Use a scan tool to read coolant temp. Should be 180F+ at all times after fully warmed up.
RustyShackle
Jun 27, 2017 06:53 AM
grensjos689
Jul 2, 2011 09:52 PM
CivicHeadd
Jun 26, 2011 11:39 PM
SALEEM
Buy, Sell, & Trade - Archive
Feb 4, 2008 12:30 AM
SUPERFLY
Sep 1, 2005 05:37 PM
