Air Conditioning Post issues with air conditioning here
01 civic ex a/c not engaging need help
Old Dec 8, 2019
Mclovin94's Avatar
Mclovin94 is an unknown quantity at this point
Need help. When pressing the a/c button the a/c light doesn't turn on. I’ve tested the compressor by jumping a relay under the hood and the clutch engages, also tested the relays and they all check out fine.
I’ve searched online and can't seem to figure out what the problem is someone help!
Old Dec 8, 2019
Wankenstein's Avatar
Re: 01 civic ex a/c not engaging need help
Check all related fuses. Also, could be a break in the wiring behind the climate control.
Old Dec 9, 2019
Mclovin94's Avatar
All fuses check out good, a break as in a wire cut? I’ll check that as soon as i get the chance.
Old Dec 9, 2019
not cut, but a point within an insulated wire that's causing poor connection. Could be loose or poor connecting harness clip/pins as well?
Old Dec 12, 2019
Mclovin94's Avatar
All the wires checked out fine. 😩
Old Dec 12, 2019
Colin42's Avatar
Could be the control panel is bad, would be like $10 at the junkyard
Old Dec 13, 2019
Mclovin94's Avatar
Ima go and see if i can find that tomorrow and get back at you with the results.
thanks for replying!
Cjones29456
Electronics
Apr 28, 2019 08:27 PM
theRedhatch
May 9, 2017 07:14 AM
kaipederson
Jun 6, 2014 08:21 PM
fourtwenty
May 7, 2013 09:24 PM
twista13
Jun 21, 2007 02:48 PM
