Air Conditioning Post issues with air conditioning here
Evaporator drain
Old Jul 8, 2012
302man's Avatar
302man is an unknown quantity at this point
Evaporator drain
My 07 civic 4 door LX is not draining the condensation from the evaporator. Its collecting inside and running on the floor board. Last week I used my air compressor and blew the line out from below....it worked...but its back again.
Anyone have a breakdown of the dash or how I can get to the drain inside ? I am thinking I am going to pull the fan motor and see if that gets me close.
Thanks !
Old Jul 8, 2012
Re: Evaporator drain
Blowing an obstruction back up into the heater case just gave it a chance to plug up again later on.
The evap core is inside the top of the heater case, in the middle of the dash.
Accessing/removing the evaporator won't give you access to the drain though IIRC.
To pull the heater case, you must pull the dashboard.
One heck of a lot of work if you ask me.
I don't really know of any cheats that would gain access to the drain area of the heater case.
Is the cabin filter intact? Where would any debris have come from?
Sorry, not much help with this one, I guess.
Old Jul 8, 2012
302man's Avatar
Yes, the cabin filter is still there. I just pulled it and checked it out. I understand that the crap that clogged it up still might be in there. But you should always try the easy and cheap first ! I think sometimes there could be a slim buildup in there. Kinda like your home AC does....sometimes it just slims up and drys up...overtime it gets solid.
Old Jul 8, 2012
Didja try going after it with a pick up tool through the (drain) hole in the floor (bottom of the housing)?
I was thinking of one of these
with a set of fingers on the end, like this
Maybe you could grab the obstruction and pull it out, or break it up.
Munzy
21
Oct 7, 2015 07:48 AM
Raiool
Oct 1, 2015 10:42 AM
Whitexj
Sep 30, 2015 02:04 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
General DIY
Sep 25, 2015 08:02 PM
