Air Conditioning Post issues with air conditioning here
ep3 a/c problem
Old Jan 29, 2009
smoke1's Avatar
smoke1 is an unknown quantity at this point
ep3 a/c problem
I'm having a problem with my a/c and was hoping someone here could help? I have an 04 civic si and the ac stopped blowing. When you first turn the car on and turn the ac on the condenser fan comes on for a couple seconds and then turns off,also no air comes out of the vents as if the blower is not working? Could this be a relay issue? If so where are the relays located? Any help would be greatly appreiciated
Old Jan 29, 2009
hndrider's Avatar
hndrider is on a distinguished road
Re: ep3 a/c problem
You have a manual controls? When you turn to a fan setting no air comes out? Sounds like a heater motor resister is shot.
When you run hot air, does fan still not work?
Old Jan 30, 2009
smoke1's Avatar
Re: ep3 a/c problem
yes i do have manual controls and no it does not blow on heat
Old Jan 16, 2025
Ep3bby's Avatar
Ep3bby is an unknown quantity at this point
Re: ep3 a/c problem
any solution I have the exact same issue
garden772
Sep 15, 2020 01:04 PM
psi 2148
Sep 17, 2018 06:31 PM
Possum-Pie
Jul 30, 2018 04:22 AM
crashintoty
Nov 5, 2015 08:18 PM
surelock22
Air Conditioning
Mar 5, 2013 11:52 AM
