Air Conditioning Post issues with air conditioning here
bypassing the ac compressor????
Old Jul 23, 2008
2k3civicgyrl's Avatar
2k3civicgyrl is an unknown quantity at this point
i have an 03 civic that is quite pissed at me right now in that the ac clutch blew up, then the ac compressor seezed, and after getting that fixed, it is about to seeze AGAIN! can n e 1 help me? i want to bypass the ac compressor but im not sure how or what size belt to buy to do so properly. i just want to bypass it until i have the money to get the whole ac system replaced. n e suggestions?
Old Jul 23, 2008
speedfoos's Avatar
Re: bypassing the ac compressor????
That's an easy one as I did something similar after removing my A/C compressor. You just need to buy an alternator belt for a 2001 Civic DX. They came stock without A/C and that belt will fit.
Old Jul 23, 2008
alright thanks! i will try that!!!
Old Jul 18, 2010
jtobin's Avatar
jtobin is an unknown quantity at this point
Will this work on a 2002 dx model?
Old Aug 16, 2013
amandakathleen's Avatar
amandakathleen is an unknown quantity at this point
will this work with a 2002 model?
Old Aug 16, 2013
Yes.
Old Sep 22, 2015
marciano117's Avatar
marciano117 is an unknown quantity at this point
Did anyone get this to work? I have an 02 Civic with a failing compressor causing power problems cause it is messing with the belt and the alternator.
Old Sep 22, 2015
Many times. Read post #2 in this thread. Get the alt belt for a DX without AC.
Old Jul 5, 2016
banjoh88's Avatar
banjoh88 is an unknown quantity at this point
Is it possible to bypass an A/C compressor on a 2001 Honda Civic EX? If so, how?
Old Jul 5, 2016
Read this thread.
Old Dec 4, 2016
BeTheBallers's Avatar
BeTheBallers is an unknown quantity at this point
Thanks for this info. It worked great for me for a 2002 Civic EX. Found belt 5060340 at an Advance near me, but not many had this belt. Seized compressor does not interfere with new belt going from crank to alternator. I was missing the adjusting bolt on the alternator so had a hard time trying to tighten the belt. Part not available near me, so went to home depot and got a Hex bolt M8-1.25 x 65mm, class 8-coarse. It worked perfect and was easy to tighten belt. One question, should I remove ac fuse? Just wondering what effect if ac button gets turned on since system still seems to be charged. Thanks
Old Dec 4, 2016
Checked a wiring diagram. I would not pull the fuse, because that may also disable one of the radiator fans.
I'd open the engine compartment fuse box and remove the relay for the AC compressor clutch instead.
Relay labeled D in this diagram:
Old Dec 25, 2016
ascraig's Avatar
ascraig is an unknown quantity at this point
Will a serpentine belt for a 2011 Honda Civic 1.8L without AC fit if I want to bypass the AC compressor or, will I need a different length?
Old Dec 25, 2016
Assuming you have a 2011, a belt for a car without AC would get the job done quick and simple
I prefer to fix the real problems though.
Old Aug 14, 2018
Tomicio's Avatar
Tomicio is an unknown quantity at this point
Will this work for a 2005 ex/ 1.7L?
Old Aug 14, 2018
Colin42's Avatar
yes just order the belt for a dx without ac
Old Aug 14, 2018
Tomicio's Avatar
Much appreciated, good sir.
Old Dec 3, 2019
Hondasheadaches's Avatar
Hondasheadaches is an unknown quantity at this point
Do you have to remove the old compressor to fit this belt ??
Old Dec 3, 2019
Colin42's Avatar
No........
Old Dec 3, 2019
Slumpertcivic's Avatar
Just be sure to tighten all 4 alternator mounting bolts/ wingnuts correctly.
Old Dec 23, 2019
Maddie73's Avatar
Maddie73 is an unknown quantity at this point
Hi I'm trying to bypass my 2001 Honda Civic dx
would I get another alt belt or would it be a different size. Thank you
Old Dec 23, 2019
BrotatoChip's Avatar
Super Moderator
What? The DX doesn't have A/C.
Old Dec 23, 2019
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Civic DX doesn't come with AC, at least here in America. But the belt you need to run the alternator without an AC compressor is shorter than the belt for a car with AC since it goes right from the crank pulley to the alternator pulley and doesn't have to reach the AC compressor. Just go to a parts store and tell them you need an alternator belt for your 01 Civic with no AC, they should have one.
Old Jan 30, 2020
Josh Brandt's Avatar
Josh Brandt is an unknown quantity at this point
I have a '03 Honda Civic Sport from Canada, The a.c. unit is about to seize or melt the serpentine belt. Will the alternator belt for a '01 Civic work to bypass it? Any help would be greatly appreciated.
Old Jan 31, 2020
Colin42's Avatar
Did you not read the thread? All you need is a non-AC belt
Old Jan 31, 2020
Thank you for the info and yes I read it all. Just making sure before I buy the part. I'm new to working on cars and since its a Canadian car I wasn't sure if it needed different parts.
Old Mar 2, 2020
Billwest28's Avatar
Billwest28 is an unknown quantity at this point
Will this "quick fix" work on a 2006 civic aswell?
Old Mar 2, 2020
Yes. Just get a belt for the DX model, those don't come with AC.
Old Aug 18, 2020
carterh062's Avatar
carterh062 is an unknown quantity at this point
Hey for the record, I just did this on my 2003 Honda Civic Hatchback 5-door (EU model). My compressor had been making noise for a bit, so I stopped driving but periodically had been running the car in idle in the parking lot. Finally one day the compressor seized entirely and the engine would not start.
I wasn't able to find the DX model, but through a lot of research online on what other people did, I figured out that the correct belt length to bypass the compressor was ~865mm so i bought a 6PK862 belt and just attached it last night and it's working very well. I do not have power steering, so it was extremely easy to install as I just removed the old belt and installed my new one without looping around the compressor (just alternator and crankshaft).
Thanks to everyone on this thread for the advice!
Old Aug 18, 2020
Glad to hear it worked out for you!
