Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Hard/Long Start and Overheating
Old Apr 14, 2025
AZDetailer's Avatar
AZDetailer is an unknown quantity at this point
I am trying to help my daughter with a couple of issues on her car.
2003 LX 1.7l
225K miles
No CEL
No stored codes.
Trying to start it results in a long crank time with pedal to the floor. After about 15 secs it will finally catch and start although idle is rough at around 800 RPM's. Giving it some gas smoothes right out and will idle but rough.
Allowing it to achieve operating temp will cycle the fans and maintain around 215°F temp.
As soon as I drive it, the gauge goes up all the way within 500 ft.
Allowing it to sit results in the fans cycling on and off until it cools back down to approx halfway on the gauge.
I can start the car and let it run for 5 mins then shut it down and attempting to restart it is met with the same starting process described above.
What might be causing the long crank time and flooded-lije condition while starting and why does it remain cool while idling but immediately overheat when I attempt to drive it after allowing it to warm up?
If I drive it right after starting it, the car runs and drives smoothly for a couple of miles but then the temp gay6ge starts moving up until I have to shut it down to prevent it overheating.
Thank you for reading and any help you can impart.
Steve
Old Apr 14, 2025
FRSam's Avatar
Click Here
Re: Hard/Long Start and Overheating
How's the coolant level in the overflow tank? Sounds like you're in failed head gasket territory.
Old Apr 16, 2025
AZDetailer's Avatar
Discovered the coolant isn't circulating. Tested the thermostat and figured out it's the water pump not circulating
Definitely a head gasket. Fom overheating.
JoshCivic
Idle Issues
Apr 17, 2023 07:49 PM
cheiscampos90
Feb 23, 2018 06:26 PM
EthanJM
32
Sep 17, 2016 06:39 PM
munozj
Mar 11, 2015 11:41 PM
mrexrode
16
May 30, 2013 07:19 PM
