Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2001 honda civic ex crank no start
Old Sep 16, 2022
Cheyenne1978's Avatar
Cheyenne1978 is an unknown quantity at this point
Hi everyone I really need help I own a 2001 honda civic ex manual and today the weirdest thing happened I went to start it and it fired up I let it warm up a little but once I pull down my E brake and put it into gear I release the clutch slowly and it took I don’t know maybe 10 steps and died and now it won’t turn over it cranks but won’t start I check for spark and that’s good I can hear the pump and through starting fluid in the intake manifold but vehicle will still not start when it cranks it don’t seem to really try to shake like when it’s about to start can anyone help me please I have no codes or anything please and thank you
Old Sep 17, 2022
Re: 2001 honda civic ex crank no start
is the engine actually turning?
Old Sep 17, 2022
Colin42's Avatar
Timing belt?
Green key flashing in the dash?
Old Sep 17, 2022
Yea I see the pulleys turn and everything which is weird to me and the key flashes only when you turn the ignition off and when you turn it on it stays solid then Disappears
Old Sep 17, 2022
Check timing
https://www.civicforums.com/forums/1...ne-timing.html
Old Sep 18, 2022
Okay I’m gonna have to check it out on money good thing I have another car for now but really wanna get it fixed and thank you so much for reply’s and helping me
Old Sep 18, 2022
if you end up having to change sensors, only use OEM, Hondas don't like aftermarket sensors. They are either Denso or NTK.
another is to try to start with camshaft sensor unplugged.
another is to remove plugs and check if engine is flooded now
CaptAdamCoop420
Dec 8, 2020 08:31 AM
Patrick Flores
Nov 13, 2020 06:48 AM
msv96
Mar 17, 2020 08:40 PM
co2wen
Jan 16, 2019 05:50 AM
TuRtLE714
South Cali
32
Jun 14, 2005 08:59 PM
