Engine start problems Post issues with engine start here. Does not start, does not run, etc.
New user. Son's Civic won't start.
Old Nov 24, 2018
rose62's Avatar
rose62 is an unknown quantity at this point
He's not too familiar with using these forums and his car is dead in the water. It was running fine when he parked it. Now nothing. Lights work and the battery seems hot. However, lights don't dim when he turns the key while trying to start it. He thought that he ruined the engine by running it low on oil, but though it is low, it has oil in it and the light never came on so, I think that's not the issue. Start neutral switch perhaps? It's an '05, by the way.
Old Nov 24, 2018
Colin42's Avatar
Re: New user. Son's Civic won't start.
If it won't start in park you can see if it will start in neutral.
Or if it's manual you can bypass the clutch switch. Also if it's manual try bump starting it.
I would try giving the starter a smack, it's on top of the trans.
Check all the important connections are clean and tight.
Old Nov 24, 2018
rose62's Avatar
All sensible suggestions. I've given him the link so he can read the responses. Thank you sir. And it is a manual.
Old Nov 24, 2018
Colin42's Avatar
Bump start it then, if you always park downhill you don't even need to replace the starter
Old Nov 26, 2018
rose62's Avatar
I looked at it today. I hear a relay on the passenger side pulling in so I'm pretty sure the ignition switch is ok. But, the lights don't dim at all when the key is turned to start. I've told him that when he can he should remove the airbox so I can see if I'm getting power to the solenoid. Tapped on the starter with a rod but no effect.
Old Nov 26, 2018
So this is a 'no crank' situation?
Starter inop....look on the drivers floor for crumbled chunks of a disc about the size of a dime, it was located on a tab on the clutch pedal where the switch plunger makes contact.. If this little disc (pad) is missing, the switch won't work.
NOTE: the clutch pedal has two switches. The first switch you see is not the one for the starter...the one for the starter safety is located high up on the pedal.
Also: The pedal must reach the floor when it's pushed down. Make sure the floor mat isn't wadded up under the clutch pedal. (People actually have cars towed in to the shop because of this)
Old Nov 26, 2018
Colin42's Avatar
Bump starting didn't work?
Old Nov 26, 2018
You mean "push start"?
Old Nov 26, 2018
Colin42's Avatar
Yeah, I tend to use both terms interchangably
Old Nov 27, 2018
rose62's Avatar
Yes, no-crank. I will inspect for this situation this afternoon. From the way it occurred it could very well be the problem. He drove the car home from school, turned it off and, poof, nothing.
Old Nov 27, 2018
rose62's Avatar
The plastic actuator is intact. But I wasn't sure if it was making the switch. I assume that the switch is NO so I pulled the connector and jumped the wires together. Still nothing. No solenoid noise or clicking of any kind except if I'm standing in front of the car with the hood open and then I hear that relay on the passenger side click slightly. As I said, the lights don't dim and no other detectable indication that it's dumping any current to the starting circuit, at all. What is the function of the other switch related to the clutch pedal?
Old Nov 28, 2018
Colin42's Avatar
one's to cancel cruise control, one's for starting the engine
Old Nov 28, 2018
Take the handy voltmeter (or $3 test light) to the starter and do some testing.
Old Nov 28, 2018
rose62's Avatar
Yeah, I've got a digital meter. The air-box has to come out to get to those connections. I had asked the son to remove it so I could test but after reading the thing about the pedal pad, I said to hold off. Now it's going to have to come off.
Old Nov 30, 2018
rose62's Avatar
Anyone else chime in?
Old Nov 30, 2018
Colin42's Avatar
Ezone is one of, if not the most knowledgeable people on this forum. I'd get out the volt-meter/test light and start checking for voltage drop.
You never answered my question if you could push start it or not
Old Nov 30, 2018
Someone actually doing some testing is much more beneficial and productive, it provides tangible test results that (hopefully) leads to THE correct repair. No guessing.
Where's that $3 test light?
Old Dec 5, 2018
civicsiduke's Avatar
civicsiduke is an unknown quantity at this point
Bet ya'll a dollar they are looking at the brake light switch,the cruise switch ,but not the important switch way way up high inside the clutch pedal cavity.You cant see it unless the top of your forehead is pressing in the clutch pedal while you hold a flashlight in pain.
Old Dec 5, 2018
Put a koozie on your pedal and try it.Take your seat out for best results because you must be on your back with your head looking up into it.TIGHT!!!
bowie
Jan 21, 2018 09:29 PM
peaches
Nov 8, 2012 03:39 PM
thatboi901
Jun 15, 2011 10:48 AM
dxman10
Feb 28, 2011 11:02 PM
Tryppi
Oct 6, 2008 07:53 PM
