Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2002 civic ex wont start
Old May 10, 2016
yota's Avatar
yota is an unknown quantity at this point
2002 civic ex cranks but wont start. to this point I have changed cam sensor and crank position sensor. Fuel pump working gets fuel to the rail will try to start with starter fluid. Checked 3 relays behind glove box(Brown, blue and black) looking for main relay(EFI) help please
Old May 10, 2016
yota's Avatar
Re: 2002 civic ex wont start
checked injectors with noid and no pressure at injectors . I was told this is main relay. Problem is locating the relay.
Old May 10, 2016
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
[QUOTE=yota;4707498]checked injectors with noid and no pressure at injectors . I was told this is main relay. Problem is locating the https://www.google.com/search?q=civi...yO6uBrmwN_M%3A
Old May 11, 2016
Relays are behind the glove box. Flop the box all the way down like you're gonna replace the cabin filter set.
Old May 11, 2016
yota's Avatar
OK changed both relays still no start. I forgot to mention there is no green key light coming on. In my 2001 it comes on for a second when you first turn the key on and when you turn the car off. I seem to remember this car having the same green key light but it is not coming on at all. Could this be my problem??? If so, what is the fix???
Old May 11, 2016
.....Could this be my problem???
That's a clue.
Figure out why.
I'd find a wiring diagram and see how it gets power and ground, what controls it, and go from there.
Engine compartment box fuses 6 and 9
dash box fuse 17
If the PGMFI main relay #1 doesn't switch on power for some reason, the immobilizer unit won't work right
Old May 11, 2016
yota's Avatar
Is the PGMFI main relay #1 the brown relay behind the glove box?
Old May 11, 2016
I dunno. I never trust because after this many years it might not be how the factory built it. What color relays did YOU install?
I have to refer to a real wiring diagram, check colors of all the wires going into the relays.
There are several relays there, I have one diagram saying the black relay is for the reverse lights, 2 blue relays are mains 1 and 2, and not a word about a brown relay at all. If it has an AF sensor (04-05) the relay for that is in the same place too.
Old May 11, 2016
Main relay #1 wire colors
white/black
white/black
red/yellow
yellow/black
Old May 11, 2016
Main relay #2 (fuel pump) wire colors
yellow/black
yellow/black
green/yellow
yellow/green
Old Nov 5, 2025
nut33355's Avatar
nut33355 is an unknown quantity at this point
did you ever figure out the problem? I’m having the same problem and can’t figure it out?
dannyboy8793
Nov 1, 2015 11:51 PM
R Steele
Oct 22, 2015 05:09 AM
Sledge
Dec 7, 2001 12:09 PM
xtremedreams
Bolt-on Engine Performance
Nov 14, 2001 12:30 PM
GoCivicRacerGo
Nov 13, 2001 10:24 PM
