Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Need help em2 wont start
Old Jun 20, 2011
roushman's Avatar
roushman is an unknown quantity at this point
Hey i got a 2001 civic ex has 137xxx miles. i went away for the weekend and the car sat for 3 days. got back and it started just fine. Drove it home and than it sat for 2 more days. after those 2 days it wont start anymore. checked the battery and it didnt hold a charge so i replaced the battery. Car still wont start. I shoot engine starter into the intake when i try and start my car and it gets it turning but wont start. spark plugs are new, just had a schedule maintenance, starter is fine and fuel pump works. Anyone got any clue or any tests i can do to figure the problem that would be great. Thanks
Old Jun 20, 2011
wetpinkpants's Avatar
wetpinkpants is on a distinguished road
Re: Need help em2 wont start
I would pull one of the coils and see if you are getting spark. if not could be a crank shaft position sensor if no spark and some time the connections get damp from setting to long on the sensors. Might help to rent a coder reader too and do you have good compression? When was your timing belt change last?
Old Jun 21, 2011
roushman's Avatar
Timing belts were changed around 7k miles ago. I will check the coils and the crank sensor. I will also get my hands on a code reader. Thanks for the advice
Wild Cranker
427
Jan 28, 2016 06:49 PM
elitezdc5
May 26, 2015 05:46 PM
em2_k20a
May 19, 2015 03:36 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
