Engine start problems Post issues with engine start here. Does not start, does not run, etc.
stalled and wont start- glowing cat
Old Sep 26, 2006
deanob's Avatar
deanob is an unknown quantity at this point
Hello everyone, I have a strange problem and I thought I'd ask you all before I call Honda directly with some diagnostic tips. I work for Acura btw so I have access to service bulletins and the HIDS program.
2001 Civic LX Coupe
The car stalled on the highway, threw sparks out the exhaust while pulling over and getting on the gas trying to keep the revs up.
Pulled over and the cat was glowing red, car cranks now but wont start.
There is no CEL
There is no Immb. key flashing while cranking
There IS a batt. light while cranking
The ECU has been reset
There is no Exhaust Leaks
Fuel Pump is running
Oil is clean and fresh
There is a bit of compression coming out the exhaust while cranking, if normal or weak I am not sure.
I'm thinking it might be the cat being clogged, to much pressure for the exhaust to exit thus not starting. Again, NO CEL present. I do have an SRS but I disabled that manually with the HIDS to save my airbags.
Any suggestions welcome before I start ripping into the block/headers and cat.
Thanks
Old Sep 29, 2006
deanob's Avatar
Problem solved all. Pulling plug/coil no.4 revlealed a pool of oil. Assuming this was shorting the rest of the plugs accross the board.
My cat now needs replacement due to running so lean (b/c of spark no.4) and the ECM reports faulted 2nd o2.
FYI all
Old Sep 30, 2006
streetglower's Avatar
a pool of oil in 1 cylinder will not result in any shorting out of anything, especially other cylinders. that doesnt even make since. now you have other issues if there is a pool of oil in 1 cylinder. either the rings are broken, or your intake valve seals are leaking or the guides are worn.
But if the cat is glowing red then it is clogged. that is why the car wouldnt start. not because 1 cylinder is dead. your car will start with a misfire in 1 cylinder. it will run rough, but will start.
Old Sep 30, 2006
timbo's Avatar
timbo is an unknown quantity at this point
As for the oil in cylinder #1 check the valve cover gaskets around the spark plug tubes and replace the cat.
Old Sep 30, 2006
could just be a broken valve cover gasket but this isnt the main problem anyway
Luluharp
Sep 27, 2015 11:56 AM
blizza
Sep 20, 2015 04:09 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
2.0.0.2
Sep 14, 2015 06:38 PM
thaler4cuse
Sep 7, 2015 08:25 PM
