Head Gasket question
Old Jun 5, 2025
jde68's Avatar
jde68 is an unknown quantity at this point
2000 Honda Civic LX 250,000 miles on it. Well maintained car, I have owned it for the past six years and bought it from the original owner. Every so many months, I have to add fluid to the over flow bottle. Radiator is always full when I do. The oil looks clean the radiator fluid looks clean. Car has only ever overheated a few years ago because of a bad radiator. I want to take this car on a long trip next month. Should I be concerned about the head gasket? I will more than likely take it to get a leak test but I am just curious what your thoughts are.
Old Jun 5, 2025
Colin42's Avatar
Re: Head Gasket question
How many months? How much driving do you do in a month? How much fluid? Do you live in a hot climate?
no evidence of external leaks?
You'd probably be fine as long as you kept your eye on the level.
Old Jun 5, 2025
jde68's Avatar
Around 700 miles every three months fill overflow to fill line not hot at all. The trip I want to take will be 2700 miles round trip and it will be in the heat 100 plus degrees on some days. I plan on replacing the thermostat, the radiator with a 2 core aluminum and a better fan
Old Jun 6, 2025
Colin42's Avatar
If you're just filling the bottle every 3 months you should be fine, especially if you keep an eye on it. Typically when these cars have a head gasket failure they push coolant into the bottle
whittam
Dec 20, 2014 04:20 PM
akronoh77
17
Sep 2, 2014 10:16 PM
Landry
Apr 13, 2014 07:58 PM
flatty
29
Dec 7, 2013 11:05 PM
drmcstford
36
Feb 18, 2013 03:42 PM
