White smoke when accelerating
Old Mar 9, 2022
Prime's Avatar
Prime is an unknown quantity at this point
I noticed when after 10 minutes of driving when I accelerate my engine jus revs out and white smoke comes out , I can smell the fluid in the smoke. What might be the problem.
Old Mar 9, 2022
FRSam's Avatar
Click Here
Re: White smoke when accelerating
Sounds like you're burning coolant. Check your oil. Head gasket may be toast.
Old Mar 11, 2022
Prime's Avatar
A bad seal was causing the leak resulting in the smoking..what happened now is the car no longer select D4 or D3 only l2 my guess the other gears burned out
any links to get a rebuilt kit?
Old Mar 11, 2022
BrotatoChip's Avatar
Super Moderator
My first question, are you capable of rebuilding an auto transmission? I have done head gaskets, timing belts, engine rebuilds, and manual transmission rebuilds. Even I wouldn't feel comfortable rebuilding an auto transmission.
Old Mar 11, 2022
Colin42's Avatar
Yeah there's dark magic and wizardry in there. Pull the trans yourself and bring it to a rebuild shop
CivicMexicano
Apr 11, 2003 12:36 AM
Outkast27
Dec 5, 2002 07:26 PM
PhantomRacr
Dec 3, 2002 12:54 AM
