2000 civic si seems to run rich
Old May 11, 2020
Josh Nebroskie's Avatar
Josh Nebroskie is an unknown quantity at this point
The car sat for 10 years be for I got it from an old couple who's son was a Honda tech and meticulously kept both the interior and exterior clean and did a couple mods to my knoledge(full dx series exhaust, forged rods and pistons, Hondas s200, obd2 to obd1 conversion) I started driving the car recently and at first it had some starting issues so I replaces cap, rotor, and stark plugs seemed to fix that then I let it in storage for the winter till recently I started dailying it and it seems to run rich. Black spark plugs hard time idling (sometimes it will idle normally) mostly after a warm restart and sometimes stalls at a stop. Then today I started it after getting some gas and it wouldn't go over 600 rpm no matter how much pedal till I kept it there for a min then it revved back to like like normal. It seems to do this most times I restart it after it getting to operation temp. I checked the basics like knock sensor and cleaned the tpms and coach. The car runs under load decently never had a problem accelerating it's just when it's idling and being started.
Old May 11, 2020
Colin42's Avatar
Re: 2000 civic si seems to run rich
Probably something to do with the s200 that's an aftermarket ecu/tune thing right?
Old May 12, 2020
I was thinking that but it seems to be more sensor related than ecu j did get a check engine today I'm gonna check out and go from there
honudad
May 21, 2016 04:35 PM
sruger
Nov 15, 2015 02:52 PM
raidermaniac
Mar 1, 2014 11:11 AM
blacksiVTEC
Aug 20, 2012 06:29 PM
blacksiVTEC
Aug 20, 2012 05:28 PM
