Oil leak on an unknown valve
Old Dec 26, 2019
Iluvmybucket's Avatar
Iluvmybucket is an unknown quantity at this point
I have a pretty bad oil leak on my 98 Civic EX. I am pretty sure I can fix it but I don't know the name of the part to buy. Definitely a bad gasket though. have some photos attached. I've searched online and can't seem to generate the right combination of words to find an answer. Please help! I luv my bucket and hate to see it cry tears so black.
Old Dec 26, 2019
Colin42's Avatar
Re: Oil leak on an unknown valve
Valve cover gasket or distributor o-ring, probably both
Old Dec 26, 2019
Wankenstein's Avatar
I agree. Also, I wouldn't be surprised if one or both Vtec gaskets are leaking as well.
OP...Buy some Gunk brand or other engine de-greaser, a bunch of disposable rags and start from the top down to clean the engine and transmission. Best to remove the air intake pipe for better access to the engine. Also, take a good look and feel at the heater/coolant hose that connects to the cylinder head directly under the distributor. Leaking, hot oil can degrade that heater hose quickly, which can lead to a leaking coolant hose and possibly a blown head gasket due to low coolant. Always track oils leaks from the top of the engine downwards.
Old Dec 27, 2019
Thanks a million! Gonna go to the parts store today and get this all rectified.
G_ROBB89
Dec 10, 2019 12:18 PM
fvckbg
Aug 19, 2016 10:17 PM
iliketogetdirty
Apr 11, 2016 11:08 PM
crg553
Jan 14, 2012 09:12 PM
7genmarathon
Mar 1, 2011 08:38 PM
