Electrical Post your Electrical issues here!
Pegged temperature gauge (2000 DX)
Old May 4, 2009
themovielife's Avatar
themovielife is an unknown quantity at this point
In the winter my temperature gauge pegged a few times. It went away for a while and now it pegs as soon as the car turns on. I replaced the temperature sending unit. The problem persists. I'm fairly certain that I've seen the cooling fan on once while this problem was going on. Any other ideas guys?
Old May 4, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Pegged temperature gauge (2000 DX)
Thermostat possibly. Is the engine actually getting that hot?
Old May 4, 2009
if it pegs as soon as car starts, its a bad engine coolant temp sensor (ECT) right above the thermostat housing.
Old May 5, 2009
I already replaced the thermostat when the problem was intermittent. Now that it happens as soon as I start the car - I doubt anything could get that hot that fast.
Gearbox, I'll take your advice and replace that part.
...just so we're clear. the part is right next to the sending unit, which I just replaced. Correct?
Old May 5, 2009
yup ECT sensor is the one you need to replace with a new o-ring. it tells the ecu when the engine is warmed up and it has a gradual thermistor. if it fails, it could read always hot or always cold.
Old May 11, 2009
So I replaced the ECT sensor and the gauge still pegs. Is there a fast/easy way to test the gauge and the wiring to it from the sending unit? What's the difficulty of replacing the gauge if necessary?
Old May 11, 2009
you would need to replace the entire cluster, they are cheap on ebay but you need to find the right one and also one with similar mileage. you could open yours up tho and see if the temp needle feels normal. maybe it just got off its track.
Old Jul 13, 2009
So I replaced the temperature sending unit - the problem persisted. After giving up and letting several weeks pass, I accidentally discovered that dimming the dash lights temporarily brings the temperature gauge down to where it actually should be. After a moment or two, the gauge climbs back up, along with the dash lights coming back to full brightness. Any ideas on how to rectify this? Any of you ever seen that before? Thanks for all the help!
Old Jan 27, 2021
joseochoa49708's Avatar
joseochoa49708 is an unknown quantity at this point
hello I have the same problem you solved it somehow thanks and greetings
99hondamar
Aug 27, 2017 07:49 PM
spyglass
Jun 10, 2013 06:08 PM
stigmataiz
Sep 1, 2011 08:35 PM
themovielife
Jul 22, 2011 06:22 PM
fastsho93
Apr 26, 2009 12:11 PM
