Electronics Post your questions about Electronics problems here!
OBD2A to OBD1 ecu swap for tune not idling right
Old Nov 23, 2022
BigOunce's Avatar
BigOunce is an unknown quantity at this point
Question OBD2A to OBD1 ecu swap for tune not idling right
Hey hope you guys are having a good one. Ive got a 98 civic lx 5 speed. Im fresh blood to engine tuning and am kinda just jumping in the deep end here. I've just gotten everything i need (OBD1 ECU, harness adapter, chip burner) and gotten a tune loaded on the chip successfully. However everytime I crank the car it jumps up and down like its pulling a vacuum leak (its not when I swapped to the OBD2A ecu everything was smooth and the idle was low) and then the engine light comes on and the car idles at 3000rpm. I can provide furhter info and any helps appreciated
Old Nov 23, 2022
BigOunce's Avatar
Re: OBD2A to OBD1 ecu swap for tune not idling right
Oh and i forgot to mention, the ecu came with a tune already and it had the same idling issue. Am i looking at a bad ecu?
Old Nov 24, 2022
FRSam's Avatar
Click Here
You’re either looking at a bad ECU or a bad tune.
Erf_Em2
Engine Management
May 22, 2014 04:03 PM
antrmo
May 4, 2013 02:38 PM
hondas desciple
Jul 12, 2012 10:42 PM
Silverphantom
Sep 5, 2003 01:46 AM
SuperCivic2k1
Mar 26, 2002 07:25 PM
