Electronics Post your questions about Electronics problems here!
Headlight on = engine stutter
Old Jan 22, 2020
AndreyAK's Avatar
AndreyAK is an unknown quantity at this point
Unhappy Headlight on = engine stutter
Hello,
I have a Honda Civic 99 sedan.
There is a strange occurrence in the vehicle, if the headlights are turned on (no matter if it is daylight or high) and i start to drive from a stand position the engine starts to stutter( feels like power loss for a short time) for a short time until the vehicle accelerates, and then it works normally until the car stops again and starts to move from stand position. (Important note: If i starting to moving from the standing position with a very gentle push on the gas pedal the phenomenon does not exist).
in summery: If the lights are off then everything works properly, when the headlight turned on then the vehicle stutters only from standing position.
What I have tried to do so far:
- Replace plugs
- Replace ignition wires
- Check that the alternator charges the battery by checking the voltage while the vehicle is running
- I removed the fuse from the rear lights Did not affect anything
- I removed the front fuse The motor worked properly
- i checked the ground connection in the engine bay
- the rpm gauge at the time of this phenomenon is not doping or going crazy
i don't know what to do, next i need your help guys.
Old Jan 22, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Headlight on = engine stutter
I suggest that you look at the alternator and grounds. Make sure alternator bracket bolts are tight and make good contact with chassis.
Berto
Electrical
15
Apr 1, 2021 08:29 AM
crispychris9
Dec 18, 2017 03:39 PM
roscogruen
Jun 2, 2012 05:00 PM
avantgarde84
16
Mar 2, 2010 12:15 PM
01EXswap
Oct 7, 2006 09:51 AM
