what type of repair is needed here?
Old Oct 13, 2021
sean_incali's Avatar
sean_incali is an unknown quantity at this point
hey everyone. I started a thread yesterday, but t was too general I think.
So I got t-boned by someone who ran the stop sign. I spoke with the insurance adjuster, and they don't seem too optimistic the car can be saved. i'm waiting to hear from an appraiser to make an appt to get it priced.
to be honest, I'd rather have this car get repaired than to shop for another cheapish reliable car. this thing had everything working power locks, doors, windows, mirrors, and perfect ac.
as of now, the car starts, but it sprang a coolant leak somewhere, so it can't be driven to get the doors fixed. but when i drove it home, it started and drove fine. the doors are stuck and cannot be opened. the driver's side appears to respond to the power lock except it doesn't actually move up and down as it should. the power windows seems to work fine.
google search seems to suggest the price of replacing the door can be as high as 2000 bucks, but that's can't be right... is it? if i could get the coolant leak fixed, i bet it will drive for another year or two no problem with unusable door.(not sure if it's legal in california)
what will be the most cost effective way to deal with this?
Old Oct 13, 2021
FRSam's Avatar
Click Here
Re: what type of repair is needed here?
This will most likely be written off. There looks to be more than just superficial damage around the doors. I'd plan on getting a different car, then be pleasantly surprised if it gets repaired by insurance.
Old Oct 14, 2021
the windows aren't broke, which means above the impact, everything should be ok. but that fact it doesn't open seems to suggest the center support between the front and the rear door (whatever it's called) might be bent. Not sure if that's fixable.
The main problem is obviously money. things are not really well for me and to get a another car with power windows and perfect ac is not going to be easy.
Old Oct 14, 2021
FRSam's Avatar
Click Here
If that part of the frame is damaged (which it seems to be given you can’t open the door), it’s a write-off for sure. Wayyyy too much labor will go into fixing it. Don’t do anything until you get your appraisal.
Why are power windows such a priority? I’ve had cars in the past with crank windows and it made virtually no difference. I totally get the news for AC though
Old Oct 14, 2021
I guess if it came to it,, i could live without power windows. but ac is a must. and 2001 civic with all its criticisms has been for the most part pretty reliable given that it had over 190k when i bought it and i put on about 10k since i got it about 5 years ago. i really don't drive it much, only for groceries and medical appt etc. guess i'm really not looking forward to car shopping again.
Old Oct 14, 2021
wait for insurance reply. But be prepared
Old Oct 14, 2021
Colin42's Avatar
Unfortunately it will be written off, my 05 got hit right in the driver's front wheel. Looked like it only needed a fender replaced, but all the structure/subframe underneath was damaged
Old Oct 25, 2021
ok heard back from the appraiser and the adjuster. they're offering if I were to retain the car and see if the coolant leak is fixable while I seek out a replacement, then
ACV: $3,697.00
Tax: $242.96
DMV: $23.00
Salvage: $752.09
Total: $3,210.87
To Owner: $3,210.87
if I were to let them take it
AAA Retain:
ACV: $3,697.00
Tax: $305.00
DMV: $152.00
Total: $4,154.00
To Owner: $4,154.00
Not sure if this include the injury damages. Probably not, but I'll try to check tomorrow. They were saying 900 bucks for the injuries.
What do you all think?
Old Oct 25, 2021
Colin42's Avatar
They'll give you $4100 for the car? I'd start shopping
Old Oct 25, 2021
FRSam's Avatar
Click Here
Yeah, there are definitely better cars for $4000 in my opinion
Old Oct 25, 2021
ok.. well,, what I was thinking is to keep the car and fit the coolant leak and rive it around until i find a replacement. otherwise i have no ride to anywhere, let alone to shop for a replacement. i'm really divided.
i could probably fix the coolant leak for less than 300? then i would be essentially getting 3100 bucks (4100 - salvage + coolant fix ), or so to find the replacement instead of 4100.
Old Oct 25, 2021
have you checked where the coolant is leaking from?
Old Oct 25, 2021
I tried to check, but couldn't really tell where it was coming from. but the only hit was from the side,and prior to the hit, i had literally 0 problems with the cooling system. it might just be a loose hose or something, at least i'm hoping?
Old Oct 26, 2021
Colin42's Avatar
Potentially cracked rad, you need to figure out where it's coming from
Dang3rousPuppy
Dec 3, 2012 10:12 AM
tuankillah
Nov 16, 2011 09:44 PM
spacepod2009
Aug 24, 2009 08:29 AM
caldapal08
Apr 26, 2006 11:31 PM
AntDeezy
15
Aug 21, 2003 11:05 PM
