How to manually adjust dipped beam? mk7 sport
Old Nov 18, 2018
RoryG's Avatar
RoryG is an unknown quantity at this point
My drivers side dipped beam is pointed way too low meaning I have awful visibility when on dipped beam. I believe that my headlight adjustors are not connected and wanted to know where to manually adjust them. Online I seem to find everywhere that there should be a hole somewhere near the light where I can use a screwdriver to adjust but I cant find this. Please can somebody help and tell me where to adjust them on a facelift ep2 sport. Thanks
Old Nov 18, 2018
GolNat's Avatar
Prelude Owner
Re: How to manually adjust dipped beam? mk7 sport
Are the headlights OEM? They should have a hole in them with a Phillips head screw in it that you can adjust. If they are not OEM then they may be missing or the reason for the crappy light.
Old Nov 18, 2018
Far too often I find the bulb was just not properly installed.
"It's just a stupid light bulb, anyone can replace it" Nope.
Old Nov 19, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Place Philips head screwdriver in hole at top of driver's side headlight assembly and turn clockwise to move beam up. Proper aiming is needed. Measure from ground to center dot on headlight assembly. Take this measurement less 2 inches from 25 feet away to bring beam cutoff to this level.
Old Nov 19, 2018
RoryG's Avatar
I'm not sure as I recently bought the car second hand, I've attached some photos. I cant seem to find the hole
Old Nov 20, 2018
NDNV's Avatar
Old Nov 20, 2018
NDNV's Avatar
Another shot...
Old Nov 20, 2018
NDNV's Avatar
Those were taken from an 2003 Acura EL headlamp assembly but should be similar for OEM Civic headlights.
Old May 8, 2019
02civilx's Avatar
02civilx is an unknown quantity at this point
times like these im glad im a mechanic
Dennis Roberts
Electrical
May 14, 2019 08:10 AM
mdj62488
Lighting
Apr 17, 2018 08:17 AM
gearbox
Lighting DIY
16
Nov 26, 2011 08:31 PM
XoULaBeAT
Nov 24, 2008 02:13 PM
TOOLOWCIVIC
Mar 13, 2002 11:37 AM
