Rust on back window panel
Old Jun 26, 2013
Moparboi's Avatar
Moparboi is an unknown quantity at this point
I have some rust on the back window there's the window that doesn't roll down and the one that does. There's a metal panel in the back and it's starting to rust is there a replacement panel or do I need to sand it putty it and sand and than paint it?
Old Jun 26, 2013
Moparboi's Avatar
Re: Rust on back window panel
And also rust in between the bumper and the quarter panel the usual spot how would you go about that to do this?
Old Jun 26, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Best way to beat rust-replace the part. If you can't do that because it's cost prohibitive, remove parts until you can see and access the entire rust patch. Then Sand it all off, use a rust to metal converter, prime with anti rust primer, and paint. Even then it might come back. If it's bad enough to use bondo on, I wouldn't even bother treating it but I hate body filler.
Old Jun 26, 2013
Moparboi's Avatar
Is there even a place that they have the part for the rear window? If so send me a link please
Old Jun 26, 2013
BlueEM2's Avatar
Whachya lookin at?
Need more information on your car to find the part for you.
This is for an 05 4 door DX:
http://www.hondapartscheap.com/parts...ding-protector
Only place you will find this is at a junkyard or the dealer (local or the website I posted). You can try ebay but i highly doubt you will be able to find it.
Old Jun 26, 2013
Moparboi's Avatar
It's not even there it's a small moulding in the back window you have one molding in between the front door and the back door those are the big moldings I need the other one in between the rear window that cranks down and the other rear window that doesn't crank down ill take a better pic tomorrow but ill upload another one that I took
Old Jun 27, 2013
BlueEM2's Avatar
Whachya lookin at?
I'd still be able to help you a lot better if you told me what your car is
Old Jun 27, 2013
Moparboi's Avatar
2005 civic special edition it's hard to explain it maybe a should take a pic and circle what I need to change
Old Jun 27, 2013
got2run5's Avatar
Go to a junkyard and show them what you need. I'm pretty sure they'll be able to find you one.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
beveragemp
May 25, 2015 07:11 PM
timpan
May 18, 2015 07:06 AM
drhawkinz
May 16, 2015 11:39 AM
