Vent window replacement
Old May 17, 2010
pacodub's Avatar
pacodub is an unknown quantity at this point
Guys my car (honda civic 01) got broken into and they busted the passenger rear vent window. I did order a replacement window, and I still have window trim. I was wondering if anyone had any information, docs, etc for diy window replacement.
Old May 17, 2010
Re: Vent window replacement
its a huge pain to change. you have to completely cut out the old one and clean up all surfaces before gluing on the new one and letting it set. i will see if i can find the actual instructions for doing it properly.
Old May 17, 2010
lowlife9's Avatar
there are locale auto glass companies that will come to your house and install new glass for cheap probably under $100 bucks.
Old Nov 26, 2019
JD Thurdekoos's Avatar
JD Thurdekoos is an unknown quantity at this point
I know this is an old post but just in case someone comes across it; I just recieved an estimate about having a front vent window replaced on my 2012 sedan (I'm locked out of the car).... $415.00. That's having a reputable, nationwide mobile glass company come to car. If I took it to their shop it would be $380.
Old Nov 27, 2019
thetut's Avatar
thetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of light
Would it not be cheaper to use a local locksmith with a slim jim?
rogerscivic
Exterior
May 25, 2019 06:49 PM
Project Kyra
Mar 5, 2011 10:10 PM
pacodub
May 17, 2010 01:10 PM
rutscivic
Oct 16, 2004 08:21 PM
kaizen
Aug 24, 2003 01:17 PM
