General Post issues, questions that are not in the other sub-forums
Does this look like reasonable pricing ?
Old Aug 28, 2019
SlowboyZ's Avatar
SlowboyZ is an unknown quantity at this point
My car has 222500 miles original motor and trans. I'm going on an 500 mile trip to the Bay Area from LA. And this is what my
Mechanic quoted me. I will be doing the brakes myself.
Old Aug 28, 2019
GolNat's Avatar
Prelude Owner
Re: Does this look like reasonable pricing ?
That looks high to me. A lot of that is easy DIY stuff. Get another quote. Area plays a part in price also.
Old Aug 28, 2019
Slumpertcivic's Avatar
Quick glance and you could buy all those pieces from Rockauto for 1/3 of that price.
In LA area, might be able to find a mobile mechanic that can work on a Honda with their eyes closed.
My guess, motivated, and minimal rust, I could do all that work in 2-3 hours but inevitably a bolt/nut will snap and then delays..
Old Sep 7, 2019
mikey1's Avatar
Originally Posted by Slumpertcivic
I could do all that work in 2-3 hours.
you could do front and rear shocks and control arms in 2-3 hours?
Old Sep 7, 2019
To be clear, yes.
There is no “pretense” of keeping the alignment, it wasn’t quoted in the first estimate and not in my time table either.
How long do you think it takes to drop a front side suspension?
Remove tire
Remove brake piston and unbolt line from strut, possible ABS wire as well
Remove axle nut
Remove outer tie rod connection.
Unbolt sway bar
Remove two control arm bolts
Remove top strut nuts.
Pop axle loose and pull whole assembly off in one piece.
How long do you think that takes, or more importantly, do you really think that would take more than 10 minutes to pull apart if the bolts are not rusted to ash?
Old Sep 9, 2019
mikey1's Avatar
a lot longer then 2-3 hours on a 15 year old vehicle, which is probably why the estimate is a bit high,
mechanics know they are likely to run into issues with older vehicles that will cost them extra time
Jacoburn1304
Mid West
Dec 30, 2013 03:53 PM
sdf
Mid Atlantic
Sep 2, 2009 11:42 PM
SupaCivic
Mid West
May 3, 2003 10:53 PM
bumdup
Mar 29, 2003 01:22 AM
silver2k1civic
North East
May 1, 2002 04:50 PM
