General Post issues, questions that are not in the other sub-forums
When to check the oil level (cold, running, after running)
Old Aug 18, 2013
CIV1C's Avatar
CIV1C will become famous soon enough
Probably sounds hilarious but I'm so confused how to get the most accurate reading. The only other car I've ever had this issue with was a 2003 3.5 Altima. If you check it when the car is running the oil is all the way up the stick.
I can't figure out if I'm low, normal or have to much. I think I was low so I added some but it's impossible for me to know now where I'm up to.
I think the best thing to do is drain the oil and refilling it but besides measuring how much I put it, how do I get an accurate reading?
Think I have the D17A2 engine, it's a 2001 civic ex.
Old Aug 18, 2013
GolNat's Avatar
Prelude Owner
Re: When to check the oil level (cold, running, after running)
It tells you in the back of the owners manual how much oil to put in. I change the oil, start the car, let it run for a minute then turn it off. Let it cool then check.
Really if you add the amount it tells you to then you don't need to check it. My Lx is 3.4 quarts.
The transmission oil is checked when the car is running.
Old Aug 18, 2013
clinton_hedrick's Avatar
clinton_hedrick is an unknown quantity at this point
You can't get a reading on the dipstick while the car is running. Make sure you are parked on a level surface and check the oil after the car has been off for about an hour
Old Aug 18, 2013
No, it's not.
Old Aug 18, 2013
GolNat's Avatar
Prelude Owner
Originally Posted by ezone
No, it's not.
Ok, check it at normal operating temperature. I was always told to leave it running.
Old Aug 18, 2013
CIV1C's Avatar
Thanks for the fast replies!
Looks like I've over filled it. I only drove 2 miles so I assume it'll be ok. I'll take care of it tomorrow when I have free time.
I thought you checked the automatic transmission fluid while the car was running?
Mine is a manual
Old Aug 18, 2013
Honda is the only auto manufacturer that I'm aware of that has you check ATF with the engine off.
From another thread (where is mikey1 at anyway? His owners manual is different or something.)
05 US sedan owners manual, page 159:
Check the fluid level with the engine
Park the vehicle on level ground.
Shut off the engine.
Bla, bla, bla.
05 US Coupe, p165
NOTE: For accurate results, wait at
least 60 seconds, and no more than
90 seconds, after turning off the
engine to check the fluid level.
Bla, bla, bla.
Hell, let's go waay back and look at a 1990 Civic book:
The automatic transmission fluid level is checked (with the engine
off
and the car on level ground) using the dipstick on the passenger
side of the transmission housing.
chgofirefighter
Apr 18, 2015 08:08 PM
prowl
Apr 18, 2015 07:50 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
