Electronics Post information/questions/Issues about Electronic parts here.
Any way to bypass the vehicle maintenance reminder?
Old Dec 9, 2020
Evan.andrews's Avatar
Evan.andrews is an unknown quantity at this point
I may be the only one stupid enough to try to 'upgrade' my daughter's DX to power locks. To do so, I had to install new (from junkyard) wiring harnesses and fuse block. All was fine until vehicle maintenance reminder light came one. Dealer says that there is no way to disable or bypass that system and the issue is that the instrument cluster does not know how to read the reset signal. I can't believe that this can't be turned off. Anyone have any thoughts?
Old Dec 10, 2020
123Krash's Avatar
123Krash is an unknown quantity at this point
Re: Any way to bypass the vehicle maintenance reminder?
Black Electrical Tape....
There was a post a few days ago about a TPMS lite... lead to the same fix with details.
Old Dec 10, 2020
Terrific! thanks for the direction
Old Dec 10, 2020
123Krash's Avatar
Did the dealer happen to say what diag. code was causing the reminder to be lit ?
May actually have nothing to do with the work you did...
Old Dec 11, 2020
No, the dealer did not give me any indication that there are any codes. They said I would just have to start replacing parts like the fuse block (and re-key the vehicle) and see if that works. They were really at a loss where to start but just said that because I upgraded from a different trim model, the not all the DX features would work as they didn't know what to do with the signals being sent through either the computer or 'system'. No specifics.
Old Dec 11, 2020
123Krash's Avatar
That's a strange response, but would not surprise me at my dealer...
There are auto parts places here, S. Fla., that will plug in an ODB tester, or loan/rent you one, that should be able to read the codes and give you a starting point. That maintenance minder lite usually means I need an oil change and the dealer resets is when they change the oil, the notification is generated by mileage since last reset.
LSAtexan4x4
Aug 11, 2016 10:57 PM
installer23
Jul 21, 2015 04:20 PM
Ma213802
May 18, 2015 07:01 AM
stl01civic
Dec 20, 2005 04:33 PM
skipbarber
44
May 5, 2004 03:46 PM
