I get even WORSE gas milage
Old May 17, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I seriously think theres something wrong w/ my car, but id ont feel like taking it to the dealership. 02 EX auto coupe, I get (IF IM LUCKY -- driving like a grandma in the city) around 220-240 miles per tank. That is HORRIBLE. When i drive aggresively, around 200 per tank. And I did the whole gas milage calculation thing on a trip to san diego (all highway @75 mph) and got 32.5 mpg. And thats with Iridiums... what gives?
Old May 17, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
i usually get around 230 a tank in my 5 speed DX, i drive responsibly. i dont think thats that bad.
Old May 17, 2003
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
wow i get at least 300+ on Ex...you got any mods?
Old May 17, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
360 miles...02 LX auto and that's with AC on.
Anyway, maybe the car wasn't broken in properly.
Tough question...too many things could cause it. Have your dealership look at it...
Old May 17, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Whoa that's unusual, I get 400 (min) to 430 (max) during winter months and 380 (min) to 400 (max) during summer months. I drive moderately hard at times and I do engine brake a lot, but still get good gas mileage with at least half a gallon to 1 left. What performance mods to do you have besides the iridiums? I only have intake (K&N FIPK), but since I got the intake actually get 10-20 more total miles than what I listed above. Sounds like you might have an issue, how hard are you driving it and do live in high heat and high altitude? You mpg from your SD trip sounds Ok, but your total miles don't sound right, so maybe your gas needle is just off. Are you really getting those miles from filling your tank up with 12-13 gallons or do you fill up less when the empty light comes on? Also, note sometimes the empty light comes on early then goes out after 30 or miles then comes back on another 20 or so miles.
Old May 17, 2003
R3DL1N3's Avatar
ive got an intake and exhaust and i have to fill up sometimes twice a week...yes i do drive agressively ALL the time and yes i do drive a lot
Old May 17, 2003
I'm The Shit
damn, i am concerned now, i only get around 20 or so. What are some things that could cause it?and what could be done to fix it?
Old May 17, 2003
malice29r's Avatar
malice29r is an unknown quantity at this point
When you guys calculate MPG do you use US Gallons or Imperial Gallons?
I've been getting around 34-37 MPG..mostly freeway in my '02 EX 5-speed, if going by Imperial gallons.. I probably take it to 5500 rpm 2-3 times a day when merging, which I don't think is excessive.. or "driving hard"
Old May 18, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Um ... why would US people be using Imperial gallons to calculate their mileage if all the gas pumps here are metered in US gallons? LOL
Old May 18, 2003
Ronin's Avatar
Damn, that's really low ... almost SUV numbers. Are you sure you're calculating properly? Don't go by how much you can drive on a tank ... go by the amount it takes to fill up and the miles since last fill-up.
Old May 18, 2003
flotsamm's Avatar
Did you top off the tank as closely the same as possible when you calculated your mileage? Probably wouldnt make much difference.. but who knows. Fuel economy can be affected by alot of things. Tire pressure, clogged ait filter, mechanical drag, weight, power loss such as torque converter slippage, suspension alignement, etc. If all of those seem fine and your engine it in tip top running condition then I would perhaps seek out a dealer/professional opinion. I know this doesnt help much but wtf.
Old May 18, 2003
I'm The Shit
well, my car only has 9000 miles onit and i reset the trip odometer everytime i fill up, i take that number and divide it by the number of gallons it take to fill it up. about 22 MPG
Old May 18, 2003
MangoEX's Avatar
Just Be
When i do the 32.5 mpg calculation, yes im using the dividing method... but when i tell you my total milage per tank.. i just reset the trip meter when i fill up. And guess what? I did that last time i filled up, and now the needle is EXACTLY half way down.. so its half a tank, and i have EXACTLY on the dot 100.0 miles. So I figure 100.0 miles per half a tank. I get the same numbers every time i fill up. around 100.0 miles per HALF tank = 200 miles per tank. AK, when you say engine broken in properly do you mean driven hard or driven grandmaly? I started to redline at 350 miles....
Old May 18, 2003
Ronin's Avatar
Going by where the needle is at the halfway point for mileage calculation is not accurate at all. And our Civics are known to have inaccurate gas tank gauges. In general, the needle is usually a bit lower than what's actually in the tank ... meaning there is usually more gas left in the tank than what the needle shows. I don't know if this is done on purpose, but it might make sense since a lower than normal reading will make people fill up while there's still lots of gas in the tank... before they run out of gas completely.
Old May 18, 2003
yellat110's Avatar
yellat110 is an unknown quantity at this point
This is the first time I have ever psted anything. But i think you have a seriouse prob and should just spend the dough and get it checked out. In my 2002 civic ex i the best i got was 36mpg with a whole gallon left in the tank at a fill up.. on a regular bassis i get from 32-38mpg. and that is all highway and hard driveing. I rolled my honda off the lot with 100 miles on it in Feburary and am turnig 7500. I go through 2 gallons of gas a day. And well i have never heard of a honda getting that bad of MPG. and i mean i red line at least 5-6 times a day and run my car at about 70mph going both to and from work. and have never had a mpg under 32. SO GO GET SOME HELP!! just my opion. )
Old May 18, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
My car is stock (enginewise) except for a K&N drop in filter. I average about 32MPG. Sometimes it'll be funky and my light will go on at 27, but thats about 1/10 times. I drive pretty grannyish, except maybe one high rev per tank. Yeah, I'm one of those guys that constantly look at my gas gauge. I just wonder how people like NorinnRadd get friggin 400mpg. I'm in a 4dr 5spd EX with 17s, but I should be happy for my 32mpg I guess..
Old May 19, 2003
NorrinRadd's Avatar
Actually, I never said I get 400mpg, I said it was 400 total miles before needing fill up. Rather I get about 400 miles on 11.5 gallons, which is about 34mpg.
MangoEX, like I said before along with some others it could very well be that your gas needly is just off. Honda shipped most of our cars such that the gas needle shows less than what you actually have to ensure people fill up before they run out of gas. When I did the Blue light gauges DIY I fixed the needle so it is more accurate to what gas is really left, since mine was doing the same as yours. When you fill up your tank after the empty light comes on how many gallons fill up? If it's less than 10 or 11 gallons then the issue is moot and you just have a screwy gas needle. But if it is more than 11 gallons then you definitely need to take your car into the dealership. Hope this helps...
Old May 19, 2003
NorrinRadd's Avatar
I believe the reason why I average anywhere from 34 to 37mpg is the following...
1) I use synthetic motor oil
2) Get oil change every 3000-5000 miles
3) Get my fuel injectors cleaned every 15,000 miles
4) I have a FIPK II (this increased my mpg by about 1-1.5mpg)
Other than that I don't know why else (maybe just lucky), since I do drive rather hard (lots of rev's when passing, merging, etc.).
Old May 19, 2003
fastlx's Avatar
fastlx is an unknown quantity at this point
Well, I must say that I am one of the lucky ones. I have an 03 LX 5 spd and I get at least 36mpg. I only have 1800 miles on the car but I have only filled it up 4 times (I think). I always get over 400 miles per tank and it also has some gas left in it. I drive 75% freeway with the cruise set at 70. The rest is stop and go traffic. Good luck finding the problem.
Chris
Old May 19, 2003
ak's Avatar
ak
Retired Mod
hey man, that MIGHT be the source of your problem. The first 1000 miles are supposed to be driven very lightly... without redlining. If this is the case, your only solution would be to buy a new motor...lol
btw, I was talking about the "break-in" period.
Old May 20, 2003
chughes's Avatar
chughes is an unknown quantity at this point
I drive 150 miles a day to work and back...mostly freeway 70-80mph....I get anywhere from 36-39mpg in my '01 EX Coupe with 60,000 miles....anything below 30 is seriously wrong.... i've never gotten below 32
Old May 21, 2003
Samari's Avatar
go to the dealership and check it out.
Old May 21, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
When i did that they just said that it varies car to car and ****.
Old May 23, 2003
KrasD's Avatar
KrasD is an unknown quantity at this point
That is crazy. I get about 250 too.that is BS. well its probably because i have an intake and exhaust. does intake and exhaust mess with milage. I have 15k miles already.Maybe I should go get a tune up.
Old May 23, 2003
Huh_Oh Sh*t!'s Avatar
Huh_Oh Sh*t! is an unknown quantity at this point
daymn i average about 22-24 mpg. usually get 260-280 on a full tank. i drive mostly city. man this sucks!! would a k&n drop in filter help the mileage any??
Old May 25, 2003
Voiceofid's Avatar
End Bringer
intake/exhaust
17s
01 ex auto
about 29-34mpg
SimpleUser
Apr 24, 2021 02:54 AM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
SidCivic
Sep 12, 2015 05:28 PM
CraigW
Aug 18, 2015 07:06 AM
RIPSAW
Aug 16, 2015 12:14 PM
