turn signal problem
Old May 16, 2003
TRDragon's Avatar
TRDragon is an unknown quantity at this point
turn signal problem
yesterday i just did the DIY clear headlights. after putting back the bumper and everything i wanted to check out the lights to see how they look. everything worked fine except my right turn signal. the light bulb itself works when the headlights are on but it doesnt flash when i put on my signal or hazards. the other signal works fine. also, when i turn on my right turn signal, the indicator in the car goes really fast (ricer style) and so does the tail turn signal. we took off the bumper again today to check if the connectors were connected all the way properly and to see if anything was damaged but saw nothing. anyone have any idea whats wrong? any help is much appreciated..
Old May 16, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
One of the filaments of the bulb must be blown. Check the bulb first...then replace
-Kre
Old May 16, 2003
FALKEN's Avatar
Civicforums Junkie
bulb...just go get new ones for like $4.00
Old May 16, 2003
TRDragon's Avatar
even if the light does turn on when i turn on my headlights?
Old May 16, 2003
solar's Avatar
solar is an unknown quantity at this point
Yes because I believe its a 2-filament bulb and one of the filaments is blown.
Old May 16, 2003
FALKEN's Avatar
Civicforums Junkie
yep...get a new set and install (the 21W lead is blown which is the 'turn' lead...so you only have a 5W lead working which is the 'parking' lead)
Old May 16, 2003
TRDragon's Avatar
cool! thanks alot guys
Old May 16, 2003
FALKEN's Avatar
Civicforums Junkie
no problem...
Old May 16, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
it may not be the bulb though.. could be a bad connector. to find out, turn on your hazards and fiddle with the bulb a bit.. see if it comes on. at any point.
Old May 16, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
check the ground wires for the bulbs.. mine got messed up when i was taking my bumper off and it took me forever to figure out that it was just a loose ground.
Old May 17, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
yah if u wanna make them only goes on when u signal, convert them to 7440 by cuttin the inner two flaments
Old May 17, 2003
AvrilLavigne45's Avatar
AvrilLavigne45 is an unknown quantity at this point
it is underwarrenty take it to a shop
steveneddy
May 19, 2015 02:39 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
