Vibration in Car when Clutch is Depressed
Old Apr 30, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Hi guys...My girlfriend drives a 01 LX. When her clutch is fully depressed (and I mean fully) and at a full, or close to it, stop, there is a light vibration (shutter) throughout the front end of the car. The clutch also seems to be quite a bit firmer lately. She doesn't notice it but when I drive it I did. I've found that typically LX's clutchs are much lighter than my EX clutch.
Anyone else have this problem...her car has about 25k miles on it and she drives a manual fine soooo its not something I would pin on "not knowing how to drive a manual".
Thanks,
Matt
Old Apr 30, 2003
Mox's Avatar
Mox
Mox is an unknown quantity at this point
I have a similar question, sometimes when I go to pull into a parking space, when I push the clutch in to glide into the spot, My car starts shuttering like it's going to stall. It did stall yesterday. This is the only time it does this. I haven't had a problem any other time with is shuddering or stalling. Just when I am turning to pull into a parking spot. Any ideas?
Old Apr 30, 2003
Hers stalls randomly too when the clutch is fully depressed..........
Old May 1, 2003
anyone?
Old May 1, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
The only time my "shudders" is if the clutch isn't all the way down. It has stalled randomly twice, but that's in the year ans a half I've had my car.
Old May 1, 2003
clutch is to the floor...ive tested it
Old May 9, 2003
Mox's Avatar
Mox
Mine is to the floor as well, I have had mine for a year and 3 months. Anyone elce had this problem and know what the deal is?
Old May 10, 2003
Snoop88's Avatar
Snoop88 is an unknown quantity at this point
Well i know the clutch is adjustable, so maybe something got ****ed up..
Old May 12, 2003
thats what Im thinking...that the clutch may need an adjustment...
Old May 12, 2003
Mbow's Avatar
Our clutches are self-adjusting to my knowledge. I think they have been that way for quite some time now.
Old May 12, 2003
Ok, the car is going to the dealer next tuesday. I'll let you know what the say about it, or if they can fix it.
Old May 13, 2003
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
okay, i worked with my dealership to solve this problem, its the power steering pump thats defective, its putting a load on the belts and causing it to shudder, the pump has a bad seal on the inside causing it to not glide as its supposed to and you will most definately stall if your pulling into a spot.. You will also shudder if your car is really hot and if the pump is acting up.
Old May 14, 2003
I've lost power steering in her car before without the car stalling as well....this sounds like it could be it.
Old May 14, 2003
yup, it happened to me alot... I almost sued honda for it but decided it was to much work, and instead i got free oil changes and a new set of tires out of it since the stock firestones were absolute crap!
Old May 20, 2003
Mox's Avatar
Mox
Was the work covered under warrenty? If not, how much did it run you to fix?
Old May 20, 2003
Just picked up the car....hers was a computer problem. They upgraded some software on it. I guess Honda had a bullentine out on it...
bsmiley
Apr 27, 2015 01:27 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
Blaster30
Apr 22, 2015 12:21 PM
streetglower123
Apr 12, 2015 10:56 AM
Guy01
Nov 6, 2001 03:25 PM
