Dash trim kit problems?
Old Mar 30, 2003
hondah1's Avatar
hondah1 is an unknown quantity at this point
Anyone had problems with the dash trim kits falling off? I got the metal look trim kit as a gift and the two vent trim pieces (middle one is fine) fall off after I put them on. The tape isn't sticky at all. I would just glue it or buy some 3M tape, but I figure I should just do it right. Think Honda would fix 'em?
Old Mar 31, 2003
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Mine was the same way. I got some glue that wasn't a "super glue", but was kind of a super glue/rubber cement mix. It's a "multi-purpose" glue if I remember correctly. I wanted something that would hold tight, but not so tight that it would never come off should I decide to remove the kit. It's been working great ever since I installed it, I just put a little bit over the non-sticky OEM tape.
Old Apr 1, 2003
AR's Avatar
AR
e-married to daydreamer
damn an i was thinking about getting the metal looking trim kit.
Old Apr 1, 2003
txtadik's Avatar
txtadik is an unknown quantity at this point
just make sure you guys clean the dash with alcohol or something (get all that armor-all or whatever off) so the kit will stick better
Old Apr 4, 2003
1hot01civic's Avatar
1hot01civic is an unknown quantity at this point
you definitly should clean w/ alcohol, and they make a 3m adhesive wipe that you put on before laying it down. the bad thing is once you put it down good luck!!!!
Old Apr 18, 2003
bong's Avatar
bong is an unknown quantity at this point
Use rubbing alcohol (atleast 2 application of it ie: wipe and then let dry two times). Follow that by a treatment of any kind of bonder that will allow your kit to adhere better to this "smooth" surface of the dash. I did all this prep on mine and its been so far so good.
drhawkinz
May 16, 2015 11:39 AM
GaryFishell
Apr 24, 2015 06:49 PM
dooner24
Apr 14, 2015 07:51 PM
mwwhonda
Dec 5, 2001 10:52 AM
BumpinCivic2k1
Nov 18, 2001 04:44 PM
