grinding...
Old Feb 27, 2003
bickford05's Avatar
bickford05 is an unknown quantity at this point
grinding...
This is probally normal but, whenever my abs is on I cant shift. Like when comming up to an icy stop sign, if the abs is working and i go to put the car in 1st, it grinds. Is this normal?
Old Feb 27, 2003
cdmx's Avatar
First of all why do you want to put it in first? Second will do fine, and no its not good if its grinding....Just think of it this way each time you grind your gears you putting little metal shavings in the gears and overtime this causes Damage and then before you know it your gonna have to get a new tranny) <knows to well[IMG]i/expressions/face-icon-small-nono.gif[/IMG]
Old Feb 27, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
I thought ABS only kicks in when you slam on the brakes [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
anyway, if you're slowing down, there's a locking mechanism so u can't shift into 1st while going too fast
Old Feb 27, 2003
cdmx's Avatar
Quote
[hr]Originally posted by: 01civicboi
anyway, if you're slowing down, there's a locking mechanism so u can't shift into 1st while going too fast[hr]
Exactly, i was going to say that HES RIGHT
Old Feb 27, 2003
bickford05's Avatar
it kicks in when your on ice as long as your moving
its only happend once... and you leave stopsigns in second?
Old Feb 27, 2003
bickford05's Avatar
o yeah and when it happend, i was only going like 3 mph, it was right before i got to the stop sign
Old Feb 27, 2003
KeNsHiN's Avatar
LEVA
dealership dude, i would take it to the dealership and have them check it out
Old Feb 27, 2003
4bangin's Avatar
Quote
[hr]Originally posted by: bickford05
its only happend once... and you leave stopsigns in second?[hr]
whats wrong with starting out in second?? it is perfectly fine. it is actually recommended when driving in the snow, less torque which means you will not spin as much. and i think what he meant anyway was leaving it in second until you are completely stopped, then throw it into first, or leave it in second, doesnt really matter.
Old Feb 28, 2003
bickford05's Avatar
o ok
so do you think i should go get it checked out?
Krieger
Engine Swaps
15
Oct 17, 2008 07:58 PM
mohawkboom
Feb 5, 2002 12:24 AM
