frozen gas door
Old Feb 27, 2003
betternu's Avatar
betternu is an unknown quantity at this point
frozen gas door
What do you do when you pull up to the gas station and notice your gas door is frozen? (besides come back when its warmer) Second time this has happened and its pretty frustrating
Old Feb 27, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
pee on it! (sorry i just had to say it)
You mean there is like snow/ice on it? I don't think there is much you can do it about it..
Old Feb 27, 2003
betternu's Avatar
I might try that There is none on the outside but I think it may be frozen inside maybe on the release. The lever inside the car doesn't depress and of course the gas door doesnt come open. Dont want to push too hard for fear of snapping the cable but wondered if there is another way to force the door open. Kind of a pain in the a$$ when you are low on gas, you know?
Old Feb 27, 2003
SilverCivSedan's Avatar
SilverCivSedan is an unknown quantity at this point
I was at a random gas station in the middle of nowhere (i didn't know where the hell i was, i was lost), and my gas door was frozen. Some random lady saw me trying to crack the ice that must have been in the seams and put de-icer on the door for me and used her key to get all the icy stuff from around it, and not a scratch on my car.
There are nice people in the world!
Old Feb 27, 2003
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I used a hair dryer on my old car when I had this problem. As we speak, the door is frozen on my vic too, so I've elected to just wait till it warms up.
Old Feb 27, 2003
babychai's Avatar
i want a baby hummer :)
babychai is an unknown quantity at this point
my bf knocked on the side that goes in...(left i think)
and it gave...
Old Feb 27, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
i think pee on it is fast and it works. or u can go ask for some warm water
Old Feb 27, 2003
txtadik's Avatar
txtadik is an unknown quantity at this point
them gas-stations usually have these window cleaning squeegies soaked in the -40 washer fluid right? get a squeegie then put some of that fluid on the gas-door... should be able to de-ice the door a bit...
Old Feb 28, 2003
ak's Avatar
ak
Retired Mod
Sorry, but picture this whole issue on my head makes me crack up. [IMG]i/expressions/laugh2.gif[/IMG]
This will probably NEVER happen to me. I live in California.. ha.
Spill coffee on your gas tank door?
Old Feb 28, 2003
txtadik's Avatar
Quote
[hr]Originally posted by: ak
Spill coffee on your gas tank door? [hr]
i tried that on my windshield in attempt to melt the ice (yes, my first winter in ontario hehe) and it re-froze in a matter of seconds!!!! arghhh!!! nasty brown windshield! took me forever to scrape it all off!
Old Jan 27, 2004
CivicsRdBest's Avatar
HELP!!! I need gas!!! I don't know how to get to it... The lever was pushed in and the thing didn't pop out!!!
Does anyone know how or what to do? Can I pry it open?
Old Jan 27, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Push straight in on the approximate spot of the lock... it'll give a little bit and chances are you'll hear the ice crinkle loose. Push the button in the car again and see if it pops. If not, get a fairly thick piece of plastic and trace the outline of the door, see if you can gently pry it open.
Old Jan 27, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Wow..... THAT sucks! Sure is nice in California right now.
Yeah, yeah.... I'll probably get killed in an earthquake.
HOWEVER..... being from Germany, I KNOW what it's like.
Old Jan 27, 2004
DrDre1443's Avatar
DrDre1443 is an unknown quantity at this point
Spray the door area with COLD water ( so it doesn't immediately freeze again---think----warm saliva is what makes your tongue stick to the metal pole in the christmas story!) Just use a garden hose or go thru a car wash and that should do it
Old Jan 27, 2004
I tried tracing the line with the bristles from the ice scraper/brush that I have and it got most of it... It still won't budge... Are you sure pooring water on it won't make it even worse? Where do I push? Shouldn't I be pulling?!?
Old Jan 27, 2004
tinman's Avatar
Damn!! Just how cold IS it where you are????
Old Jan 28, 2004
I can leave soda out and it's going to be colder than if I left in my fridge...
Old Jan 28, 2004
tinman's Avatar
THAT'S cold.
Old Jan 28, 2004
Hmm... I tried the hot water thing. It didn't work... I tried pushing at it at different spots... Nothing seems to work...
Old Jan 28, 2004
Come on... I really need to know... Do I pry it open somehow? Will I brake anything? Do I just get wait till I either run out of gas or it magically opens?
Old Jan 28, 2004
I finally pried it open with a spatula and some window de-icer... Now the lock is broke. Can Honda fix it?
Old Jan 28, 2004
DrDre1443's Avatar
well I told ya hot water wouldnt have worked, but if the lock is broke, that wouldn't be because of ice, maybe its a failure in the mechanism that releases the door
Old Jan 29, 2004
The thing that it latches on to is broken. The if you drive around the door just swings open now (not all the way but like if you press down on the lever) Can I just use super glue? Or do I replace it somehow?
Old Jan 29, 2004
thedude's Avatar
thedude is an unknown quantity at this point
I have the same problem - easy fix. Release the latch from inside, then take a credit card (or some other card), insert it into the space between the cover and the car, trace it all the way around and voila!
Old Jan 29, 2004
HomerSimpson's Avatar
I have the same prob all the time, usually applying some pressure to the door will crack the ice enough to open it
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MamaBear2015
May 3, 2015 02:17 PM
jonavin
73
Oct 4, 2004 07:18 PM
MiltownVtec
Jan 6, 2002 05:57 PM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
