HEADLIGHT PROBLEM PLEASE HELP!!!!!!!!!!
Old Feb 4, 2003
  #31
Gardener's Avatar
Gardener is an unknown quantity at this point
Hello Shortie22,
I am taking my car to the dealer tomorrow 02/05/03. I described the problem. They would not comment without seeing the car. I am hoping they will be accomodating. Stay tuned.
Gardener
Old Feb 4, 2003
  #32
ssmshortie's Avatar
aright im tryin to lol i work 9:30-6 tomorrow hopefully get some good news when i get home lol
Old Feb 5, 2003
  #33
Gardener's Avatar
Well...
I presented my case to the Honda dealer. They could see the burn marks on the connector. For a while the lights did NOT work, but then they wiggled things around for a while, and now they say they are working. They admit this is no guarantee they will continue to work. They are presenting a case directly to Honda (this goes beyond the dealership), particularly re: the burn marks on the connector, to see what Honda says. One difficulty, the car had been hit when in a parking lot, so they are indicating that there could be some relationship between that and the burned contacts???
I was asked to call back in a few days to see how Honda has responded.
No $ charge so far, but I still don't consider the problem fixed.
I'm really curious if yours or Rodneys' contacts have the same problem.
Rodney??
Stay tuned...
Gardener
Old Feb 5, 2003
  #34
ssmshortie's Avatar
well neither of us have heard from rodney
Old Feb 5, 2003
  #35
rodney's Avatar
rodney is an unknown quantity at this point
sorry fellas i havent been responding lately...almost not even thinking about the headlight prob....just got jl 10w7 installed and i am all smiles all the time...everyone that listens to it before seeing it swears i have 2 12s or a 15.....probably going to try the switch thing tomorrow as i am having my first off day since super bowl sunday....and hey do either of you have cleared headlights
Old Feb 6, 2003
  #36
ssmshortie's Avatar
yea i do
Old Feb 7, 2003
  #37
Gardener's Avatar
What are cleared headlights?
Gardener
Old Feb 7, 2003
  #38
ssmshortie's Avatar
lol guess u dont have em no orange colored plastic shield on ur head light cover, i took mine out but now i have an amber bulb for inspection lol but its still cleared out
Old Feb 9, 2003
  #39
Toca's Avatar
Toca is an unknown quantity at this point
The same **** happened to me today.... Both went out. I replaced the bulbs with the factory ones and now they work.
I wouldn't stress it.
Old Feb 10, 2003
  #40
ssmshortie's Avatar
well im takin my car to a mechanic tomorrow just in case there's a different problem with my car
Old Feb 11, 2003
  #41
ssmshortie's Avatar
ok toca ......... didnt work for me i still have the problem and went back to stock head lights
Old Feb 11, 2003
  #42
Toca's Avatar
Well I dunno what to tell you... It worked for me.
Old Feb 11, 2003
  #43
ssmshortie's Avatar
i sorda thought it was to weird for that to happen o well[IMG]i/expressions/face-icon-small-sad.gif[/IMG] at least now i can say i replaced my own head light bulbs lol
Old Feb 12, 2003
  #44
rodney's Avatar
alright fellas check this bullsh!t out...i go to john eagle honda today and showed them the burnt connections (yeah i have the burnt pin 6).....so they started telling me that the bulbs were the problem and that the bulbs burned the pin....so i say that if the bulbs were the prob then the highs would have burned out too right (low beams = lower wattage....high beams = higher wattage...makes sense right) well he says not necessarily (whatever) so i tell him to jack of% and ask how much the harness is so he tells me they have to sell me the entire dash harness which consists of a lot of harnesses...so i tell him to jack of% again ($166.60) for only one harness......so any way i go home to see if i can ghetto engineer something....so i am playing around with the solution my new best friend (Gardener) posted.....and i am grounding the different pins and tada low beams (i feel like i won the WWE Championship HA!)....but then the bullsh!t happens i leave the wires grounded and no beams after a second(WTF!!!!!) after so long i have tried to fix this problem and i get so close and it happens again....
so here we go i am playing with it again and it doesnt work anymore so now i think i really f@cked something up.....so i just reconnect the harness and just for kicks i turn on the low beams and they come on(guess who just won the WWE Championship again) so i turn them off and turn them on and off and on and off....and they keep working dont know what happened but i drove all the way to work with them on at 4 in the afternoon...hopefully they never go out again.....props to Gardener (THE Man!!!)
Old Feb 12, 2003
  #45
ssmshortie's Avatar
ok that still doessnt help me out
Old Feb 12, 2003
  #46
rodney's Avatar
well check out the process gardener and i went through
Old Feb 13, 2003
  #47
Gardener's Avatar
Rodney,
Do you know the wattage of the bulbs you were using? Were they a higher wattage? If not, that should not explain the burnt contacts. I am still pursuing this with my local Honda dealer. I hope to know more Friday 2/14.
Your low beams may have gone off because one of the wires lost contact (could have been the relay connection).
Mine are temporarily working, but I think it's just because remaking the contacts might scrape off some corrosion, etc. I would not count on mine or yours continuing to work.
Please save your failing connector in case you do get around to replacing it. I am also pursuing other options to document this problem. I may need your help.
Thanks,
Gardener
Old Feb 13, 2003
  #48
ssmshortie's Avatar
i noticed corosion around the wiring but like i said im taking it to a specialist tomorrow since i have the day off
Old Feb 14, 2003
  #49
Gardener's Avatar
Hello shortie22,
Please save your parts and receipts if they replace the wiring harness.
Gardener
Old Feb 14, 2003
  #50
ssmshortie's Avatar
ok the guy installed a new ground harness, he said he could trace it but that could take hours and he would have to charge me
so right now the lamps are working fine and he said i shouldnt have another problem with them i'll keep an eye on em though
also said that i had an open ground circuit in the old lamp harness?? ever heard of that
scott
Old Feb 14, 2003
  #51
Gardener's Avatar
Shortie22:
If by "old lamp harness" he means the harness that connects to the light switch, pin 12 is the ground connection. If it was completely bad, all your lights would not have worked. Do you know what "ground harness" he replaced? I hope he really fixed your problem!
My Honda dealer agreed to split costs with me, but he wants to replace the switch. I think the problem is in the harness. I am pursuing what it takes to force a recall for this problem. Don't know how successful I will be. I consider it a safety hazard for your lights to go out due to a manufacturing defect (not simply a blown fuse). This is why I am suggesting saving all parts and receipts. This is a slow process. Meanwhile, my lights are still working.
Gardener
Old Feb 17, 2003
  #52
rodney's Avatar
wuz up fellas i took my car to another honda dealer and the service manager says he will probably just fix the harness for me. the initial person i talked to was this old lady that was just a b!tch about the entire thing saying i never should have looked at the connector and as soon as i had a problem should have taken it to them....anywayz i am supposed to go monday morning and they say it should be ready by that afternoon if everything is ok so i will keep you guys notified and gardner let me know if i am correct but you dont have any modifications at all do you...the lady was trying to blame the problem on everything from my radio to my amp and sub installation even the clear headlights so just checking
Old Feb 17, 2003
  #53
Gardener's Avatar
Congratulations, Rodney. Glad to know they are making yours right.
I have no modifications. The front end was hit in a parking lot, broke the headlight, then replaced with after market equivalent. At first the dealer tried to link my problem to the accident.
My dealer said they could not "fix" the harness. The whole thing would have to be replaced, and as you know, expensive. I have the paperwork from NHTSA to register a complaint / safety issue. I am trying to thoroughly document the problem.
Rodney, are you still in warranty? Can you get the old harness connector? I may look into repairing it myself and could use the spare pins from your connector. I am happy to pay you for it. I also would like to try and take pictures for the NHTSA documentation.
Gardener
Old Feb 17, 2003
  #54
rodney's Avatar
i am still under warranty and my car was hit in an accident but on the other side of the car....at first my dealer said the same thing about an accident causing the problem.....as for the connector i wasnt able to take my car to them today because i had a couple of things come up.....when i do have it replaced i will be happy to send you the connector without any payment....Honda family right......i will keep you informed
Old Feb 18, 2003
  #55
Gardener's Avatar
That would be great if I could get the connector! I have searched junk yards, but car is too new to find parts. I hope your fix goes well.
Gardener
Old Feb 19, 2003
  #56
rodney's Avatar
NEW UPDATE!!!! finally got the issue resolved with the dealer....after fighting with them for about 3 hours and them talking to "the man" over at Honda....this problem will be fixed by the dealer at no cost to me....now we all know my story about the aftermarket bulbs....but the old lady that took my car in basically called me a liar about the bulbs in my car now [IMG]i/expressions/moon.gif[/IMG] thats okay though cuz i got her azz.....that was f@cked up the way she handled me....if anybody here goes to gillman honda to get their car serviced dont got to the old lady named christine cuz i had the worst customer service experience of my life with her but her manager got her azz too HA! just waiting on the part to come in and it will be taken of.
Old Feb 27, 2003
  #57
Gardener's Avatar
Rodney,
Any update on your fix. Since you're under warranty, Honda may not let you have the bad parts. Please ask for them, however, if you don't mind.
Thanks,
Gardener
Old Feb 28, 2003
  #58
Vezman's Avatar
Vezman is an unknown quantity at this point
I have aproblem with my headlights, but they both don't go out just the left one. I have havd my car for 7 months and its gone out a 2 times. I just switch and put tyc headlight assembly in there, same wattage, but different bulbs, and the left one went out again. I am bringing it to dealer next week. Think he will say its the headlight assembly? I do!
Old Feb 28, 2003
  #59
Gardener's Avatar
Curious,
There are 2 relays, 1 for left and 1 for right. Perhaps left relay contacts are bad. If this is the case, your high beams would also not be working on the left side.
Gardener
Old Feb 28, 2003
  #60
rodney's Avatar
Quote
[hr]Originally posted by: Gardener
Rodney,
Thanks,
Gardener[hr]
havent heard from honda yet but will i did find out i wont be able to get the parts will keep u informed though
