For those with Eibach Springs...
Old Sep 23, 2002
Gshockbreaker's Avatar
Gshockbreaker is an unknown quantity at this point
I had my Eibach Sportlines installed for about 4 months now. I still hear clinks and weird popping noises when I'm turning my wheel at a dead stop or when I'm at very slow speeds. Someone said that the springs need to be broken in, but I had mine for 4 months! Anybody?
Old Sep 23, 2002
Mbow's Avatar
You'd have much better luck checking in the suspension forum. This thread will probably be moved there shortly. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Anyhow, almost everyone that has lowered there car has the same noises that you are referring to. Do a search and someone explained how to fix it.
Old Sep 24, 2002
Kable's Avatar
Formerly known as Veritas
Kable has a spectacular aura aboutKable has a spectacular aura about
umm...i've had my eibach prokit for about half a year now and they are perfectly fine....how much drop is it? hmm...im assuming you don't have camber or aftermarket shocks[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 24, 2002
Mbow's Avatar
He is referring to sportlines, not prokits. Prokit isn't really a drop. The problems are associated with springs that actually lower the car.
Old Sep 24, 2002
1hot01civic's Avatar
1hot01civic is an unknown quantity at this point
I have sportlines also, had the same problem when I put my springs back on. here is the thread
The link for suspension
Old Sep 25, 2002
orso's Avatar
orso is an unknown quantity at this point
that happened to me. my top spring perches were turned around backwards. i took them off and put them on the right way and the noise stopped. go to honda get them to copy the service manual for you. just the suspension part and get under there and get dirty. its not that hard. just make sure everything is aligned right and grease everything up. that should fix your prob.
Old Sep 27, 2002
VNlilMAN's Avatar
The Standard One
ya the top perch has to be aligned right. also you should have a tubing around the bottom part of the spring that sits on the bottom perch. i didn't do neither so i have noises too, i'm almost positive its not doing any damage so i live with it.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Viczhou
Sep 2, 2015 07:55 PM
Shadow277
Aug 31, 2015 12:30 PM
cukaracha
Aug 29, 2015 05:27 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
