PROBLEM PEASE READ!!
Old Sep 10, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
Ok guys i have a custom cat back on my ex. well i recently have noticed that my exhaust is becoming so hot that its melting my rear bumper does anybody have any ideas to help me keep it from causing more damage to my rear bumper? thanks
Old Sep 10, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
-Trim the rear bumper
-Lower the exhaust
-Get a new bumper with a higher cut out
-Try getting some insulation, or put something ceramic in between the exhaust and the bumper
Old Sep 10, 2002
injencivic's Avatar
i was thinkin of some isulation but where could i get some? i checked with a local muffler shop and they said i would have to move it back and lower it more
Old Sep 10, 2002
taz757's Avatar
Just get some lower hangers. I bet you'll notice a major difference if you lower it even 1/4" from the bumper. Those things get pretty hot. That's what my suggestion is - just lower it by a 1/4-1/2" and you should see a major difference.
Old Sep 11, 2002
mattskav's Avatar
mattskav is an unknown quantity at this point
if you can devise a thin sheet of aluminum (avail @ hdwr stores) to hang between the two it will act as a heat shield.
heat should not be a problem on an open system as much....
Old Sep 13, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I had the same problem. I purchased an OBX B3 Bomb catback exhaust, sounds great by the way, and the brackets were too short so when it was installed, it touched my bumper and started to melt it. This is what I did, went to meineke muffler and had them adjust the hooks on the muffler to hang down lower. Unfortunately, with my any exhaust, the brackets could only go so far down before the piping would hit my sway bar and was just barely touching my bumper and when idling, I heard a terrible vibrating. To fix that, I just got a buch of twisty ties and you can put many of them together to make one big one. There is a hole right in that arch above your exhaust and I strung the ties through that and there is what I guess is part of the frame that I strung the twisty ties through and I tightened the twisty ties until the arch was high enough to where my bumper wouldn't touch my exhuast and make that annoying noise. To this day they still hold my bumper above my exhaust and I haven't had that vibrating noise yet. Hope this helps you with your problem.
Old Sep 14, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
when i got my dc sports exhaust, i asked a question about tips and they said id have to lower it, just get a torch(with the exhaust off the car), and heat it to red and pull the hanger away from the exhaust, this will lower it, you might want to put it on and off a few times if youre a perfectionist like me, but its all for the better.
Blazz
Jun 4, 2015 01:04 AM
crowtoo
May 11, 2015 06:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
McD
Apr 16, 2015 10:46 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
