easy way to check engine coolant???
Old Aug 28, 2002
manixc's Avatar
manixc is an unknown quantity at this point
is there a easier way to check the engine coolant?
rite now, i cannot really tell if my coolant is at max or min or anywhere in between??? the casing isn't transparent enough and the battery is in the way
i have my civic for a year now, has 9000+ km on it. been in the dealer once for oil change. so as far as i know, the coolant haven't been added.
and which cap do we pour the antifreeze/water in?? the white one or black one w/ the warning on it?
also, what the diff between 5w-20 for our car and 5w-30???
thx
p.s. i'm a car idiot
Old Aug 28, 2002
Freak's Avatar
Freak is an unknown quantity at this point
thats cool cause most of us are idiots... but get a flash light and look at the tank it's pretty visible to see the green or pink liquid level. And the difference between the oils is the viscosity of it... the thickness.
Old Aug 28, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
yup, just use a flashlight.
I don't recommend the 5w20 that Honda does. I use 5w30. It's better.
Old Aug 28, 2002
manixc's Avatar
thx
so the coolant is supposed to be pink or green???
i have 5w30 at home, that's why i ask
Old Sep 3, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Hola,
Engine oil, or any oil for that matter is rated for its thickness, as in viscosity. The higher the number the oil, the thicker it will be. A thick oil will provide protection while the engine is hot, a thin oil (low SAE number=thinner oil) will operate for cold temperatures. By using a 5 grade oil, friction is reduced and fuel economy is improved.
So while we drive in a mulit environment range, we must use a multi environment oil.
As for coolant, there are two kinds, the green is the normal kind that requires you to change it every two years. The orange or DexCool is specified by General Motors and lasts for 5 years. The only catch is that if you mix them, you only get the protection of the weakest one. I.E. if you use green and orange, you still have to change it every two years. But if you remove all your coolant by flushing out your system, you can add the orange coolant and get extended coverage.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
deus-ex
Apr 13, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
