HELP ON a/c and blinker
Old Aug 12, 2002
civicsedanlx01's Avatar
civicsedanlx01 is an unknown quantity at this point
okay i've had my intake installed a couple of months ago, but recently i notice that my right blinker beats really fast and my a/c doesn't work. also when my lights are on the right blinker doesn't even flash. There was a post started early that I was reading and they were talking about an o2 sensor. [IMG]i/expressions/face-icon-small-confused.gif[/IMG] The intake is the only thing that I can think of that could make this problem. HELP!!! I Need to know whats wrong.
Old Aug 12, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
wow, sounds like something got left off or something got shorted out...
just as some general advise, take a good look inside, and look at any wires/etc. around where the intake is and see if anything is just hanging or pinched...
do you have a cai or short?
Maybe it isn't even associated w/ your intake, and something else you might of done recently.
Good luck.
Old Aug 12, 2002
I have a cold air. I'll try looking for any missing wires. I took a look already but I will double check right now.
Old Aug 12, 2002
ph0ng's Avatar
I assume you saw this post: http://www.7thgencivic.com/forum/mes...threadid=35475
Old Aug 12, 2002
nope never saw that one. Thanks I will try that.
Old Aug 22, 2002
Assasin's Avatar
Assasin is an unknown quantity at this point
i had the same exact problem except for my car was overheating also the temp gauge wud go to hot if i was in stop and go traffic. but then when i started driving it wud go down. did any of yall have this problem. well i fixed the ground and the ac and signals work but not sure if it fixed the overheat problems wud u think this wud be a cause?
Old Aug 22, 2002
solar's Avatar
solar is an unknown quantity at this point
Quote
[hr]Originally posted by: Assasin
i had the same exact problem except for my car was overheating also the temp gauge wud go to hot if i was in stop and go traffic. but then when i started driving it wud go down. did any of yall have this problem. well i fixed the ground and the ac and signals work but not sure if it fixed the overheat problems wud u think this wud be a cause?[hr]
Sounds like the radiator cooling fan isn't kicking on, check to make sure all your connections are tight. The reason it cools back down when you drive is because air is being forced through the grill to the radiator. In therory you don't need a cooling fan on the radiator as long as air is drawn through and you don't stop.
h4ldol
Apr 24, 2017 08:16 PM
jtcavey
Sep 30, 2015 02:18 PM
JMKendrick
Sep 16, 2015 06:17 PM
MichaelLW
Sep 14, 2015 07:15 AM
andyandyy
Aug 4, 2015 06:37 PM
