Best place for smoke machine?
Old Oct 2, 2018
310civicEX's Avatar
310civicEX is an unknown quantity at this point
My long fuel trims are pretty high..I wanna check for vac leaks..where's the most common leaks ? And best place to hook machine up to?
Old Oct 3, 2018
Slumpertcivic's Avatar
Re: Best place for smoke machine?
Brake booster hose, nice and fat and easy to access.
I would suspect partially clogged fuel injectors vs vacuum leak if your not getting any codes.
Old Oct 3, 2018
310civicEX's Avatar
actually some of my o rings were bad on 3 injectors..maybe that was it
Old Oct 4, 2018
mac25's Avatar
Dr Krieger of Modification
Cheapest way is to cover the throttle body with tape, disconnect the brake booster line from the booster side then puff a cigar into it.
Worked for me.
shrike88
Nov 17, 2016 07:51 PM
stl01civic
Aug 21, 2015 05:33 PM
rujoesmith
Jan 3, 2015 09:28 AM
BRBRT03
Jan 14, 2014 05:49 PM
HyaBoosta
Engine Swaps
Dec 31, 2004 08:12 AM
